Lance 920?
dlduke01
I have a 2007 ford f350 srw truck and currently have a 2007 lance 815. I have an opportunity to get a 2006 lance 920. The question is can I haul it easily with out modifications to my truck? I think the weight of the 920 is about 2775 pounds. Thanks for all your input.
2007 Ford f 350 crewcab longbed srw 4x4 4" bds lift w/ 35" Nitto Trail Grapplers
2005 lance 920 loaded with sofa bed combo
2003 jeep rubicon 4.5" with a bunch of extra bells and whistles
5 REPLIES 5
Big_Rig1
I had a Lance 920 on my 2004 Dodge 3500 and it carried the camper just fine with no mods.
Big Rig
04.5 Dodge Quad,3500,CTD,DRW,4X2,48RE, Ranchos, Tatman Wedgies
2015 Arctic Fox 990, 100W solar, power rear awning, Fox Landing, no generator, no oven
FireGuard
That should be a good combo.
The lift will hurt a bit but you should be fine.
13Jeep Wrangler
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
weedrancher
I have a 920 on a Dodge Ram 2500 but with several suspension modifications. You should not any problem with the weight but you might want a beefier anti-sway bar. You can expect approx 3,600 lbs wet. Good luck!
2002 Dodge Cummins 4X4,2004 Lance 920,, Airlift suspension, Roadmaster anti-sway bar, TorkLift tie downs, Fastguns, StableLoads
I'm not on Facebook or Twitter. This is as social as I get.
mkasner
dlduke01
Can anybody give some insight? I gotta move kinda fast on the deal.
