โJul-09-2015 02:57 PM
โJul-11-2015 10:23 AM
mogman wrote:NewTTcamper wrote:
My husband I looked at the trailers as we bought a new Lance camper in 1996. Lance was great quality back then and the new ones look nice. However, my husband did not like the way the axle was built. It was not a standard set up. He's been around the block when it comes to vehicles and such. He walked away because of this issue. Anyone else notice this?
I bought my Lance because of this very reason.
Torqflex axles= 4 wheel independent suspension, ride is very smooth, no springs to break, no plastic bushings to wear out quickly.
Plus, I was, and still am, very impressed with the way the interior is constructed. Mine has had two trips across the U.S. to Florida, two trips to Southern Ca.,(a lot of the highways are less than smooth) numerous local(ish) trips, nothing has fallen off, nothing is loose, other than the original cr*p tires it's been and continues to be a great trailer.
I also changed the mattress, but that seems to be an industry-wide issue.
โJul-10-2015 08:19 PM
โJul-10-2015 08:06 PM
โJul-10-2015 05:28 PM
โJul-10-2015 05:25 PM
goducks10 wrote:
I'd take the Lance over the Jayco any day. Walk around queen is way easier to navigate than the slide out Jayco bed. Think about how you're going to put sheets on the slide out bed. No where to get dressed except in the kitchen/dinning area. You can use the inside of the Lance if you need to get a bite to eat while on the road. Better suspension on the Lance. Way bigger tanks. Nicer entertainment center. Less chance for wood rot with the Lance. JMO but the Lance would probably hold it's value better.
โJul-10-2015 03:53 PM
โJul-10-2015 01:03 PM
โJul-10-2015 12:30 PM
โJul-10-2015 11:29 AM
hohenwald48 wrote:
Just look at them and make up your own mind. Remember that all manufacturers use the same appliances, axles and other components so those will likely be equal among brands.
We looked at both and went with the Jayco. Jayco is not perfect and neither is Lance. It's just a matter of what you want. Be aware that Lance has an almost cult following so sometimes you get opinions from Lance owners that are simply repeating the mantra.
you gotta' look and decide for yourself.
โJul-10-2015 10:03 AM
โJul-10-2015 08:09 AM
โJul-10-2015 07:35 AM
โJul-10-2015 07:05 AM
โJul-10-2015 07:00 AM
jmacpolo wrote:
We are torn between a Jayco X213 and a Lance 2285. I was leaning toward the Lance even though it is much more $$ but then I ran across several reviews that really bashed the quality of the Lance trailers. I always thought Lance were high quality trailers but now I am unsure. Does anyone own Lance, and what say you about their quality?
Thanks,
John
