Apr-13-2023 07:52 PM
Sep-08-2023 08:06 AM
Sep-01-2023 08:18 PM
kevinn_63 wrote:
Incredible set up. I have a 24 AF 1150 on order with 600W solar on roof and Onan generator. Trying to find schematics and details for installing a similar system. Anything like this you can post will be appreciated. Where did you fit all of this equipment?
Will check into the batteries and removing the battery tray. Great idea!
Thanks, Kevin
Sep-01-2023 07:32 PM
Jul-10-2023 05:32 PM
riah wrote:
skanj0, We have 520 ampHr capacity LiFePO4. I bought 2 batteries from SFK, and I think they now have 280 and 300 aHr batteries available. We only initially installed 200 watts of solar, then added a dcdc 40 amp charger and installed 200 more watts of panels and found out we were over the rating the SCC capacity and had to upgrade to 40 amp SCC. That said, long story short, when we are moving we don’t seem to need to use the solar panels as the dcdc charger is keeping the batteries charged, so if you haven’t considered a dcdc charger, I highly recommend it!(.The DCDC charger also is running the absorption fridge on 12 volts saving us propane too while we’re driving.) …*** And apparently I should have read thru all the replies first lol
Jul-09-2023 08:07 PM
Jul-01-2023 05:12 PM
pianotuna wrote:
Golden_HVAC,
The best way to limit current may be a dc to DC converter (or charger). That allows for optimization of the charging voltage, too.
Jun-28-2023 05:45 PM
3 tons wrote:
That is truly a remarkable installation, possibly even the standard bearer of installs!! 🙂 GREAT Work!
3 tons
Jun-28-2023 05:40 PM
mellow wrote:
That is a sweet setup! Only thing you are lacking is a way to clean the grey water to make it drinkable again and you could stay offgrid for a long time!
Jun-28-2023 05:31 PM
Jun-28-2023 06:58 AM
Jun-27-2023 08:19 PM
Apr-19-2023 07:41 AM
Reality Check wrote:skanj0 wrote:Grit dog wrote:
Fwiw, rough roads don’t blow out LP pilot lights. Unless you happen to be going really really fast on them…
Rough as in offroad, no where near level with, side to side rocking gi.e.oing over small to medium size rocks and ledges, etc.
Still won't be the cause. A strong gust of wind, sure, but LP could care less about motion.
Apr-19-2023 07:32 AM
Apr-19-2023 05:24 AM
