leave in or keep out water heater plug winterizing?
al7601
I tried searching but a simple question. after draining HWH do you replace the plug or leave it open?
Thank you in advance
29 REPLIES 29
rbpru
I leave mine sitting next to the hole. However there is no reason not to screw it back in.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
Bigbird65
boosTT wrote:
What's the point of putting it back finger tight?
Drain it (that means remove and reinstall the plug) and be done.
I have the same question as you. A lot of folks advocate putting the plug in finger tight. After winterizing (air compressor method) I always use thread tape on the water heater plug and re-install.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
boosTT
midnightsadie
I to put a valve in, and I drain after each trip. mines 8yrs old now and no problems and a short piece of rubber hose extends it out for easy drain.I drain my water tanks to ,that way all water is fresh at the start of a trip.
Old-Biscuit
GordonThree wrote:
tn terry t wrote:
I put in a stubby 1/4 turn brass ball valve in the drain of three different rigs, works real slick
How do you keep the rigs from rusting without the anode?
Even if it isn't a Suburban that uses an anode rod (Atwood doesn't)
That drain valve will drain water but leaves scale/crud behind cause it can't flow out that small diameter opening in drain valve
Leave drain plug out UNTIL done winterizing so you can check if any anti-freeze got in water heater due to bad check valve or valving error
THEN put it back in to protect WH Tank threads and keep critters out
GordonThree
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
tn_terry_t
GordonThree
I leave mine out, I lay it inside the heater and close up the access door. World hasn't ended yet, and no "things" have made a nest inside the heater.
korbe
And to remind me in the spring that the plug is not tight I put a little flagging at the access latch door.
enblethen
Inspect the plug for rounded corners. If corners are rounded order a new one
Put back in loosely!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
gbopp
budwich wrote:
once it has been drained, put the plug back in (finger tight) to prevent "things" from crawling in.... also prevents losing said plug.
x2. I put the plug in finger tight.
DutchmenSport
Put it back in finger tight. If you don't, the threads on the plug and the threads on the water heater hole will rust up, making it very difficult to re-insert in the Spring.
Artum_Snowbird
I usually put mine in one turn, but not tight. Same as hot and cold drains, and fresh water tank drain. Sewage dump is checked to be sure pink has reached both black and grey valves.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
janstey58
I put mine back in, I don't want small critters making a winter home in there.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
budwich
