Level
cliffy49
Need some advice from the folks here. I went out and purchased a level that screws to the front of the trailer. The thing is huge (11 x 3) but is easy to see and should help me level with out getting out of the truck to see.
My concern is that after getting the level home I started thinking about putting screws into the fiberglass nose. Has anyone used one of these and what do you think about putting 4 screws into the nose piece of my trailer. I know to add some type of caulking around the screws when putting them into the trailer, but what about the longevity and durability of the level and it staying where ever it is placed. Also, what are the chances that the screws will start cracking the fiberglass?
Thanks in advance for all you help.
cliffy49
2016 F150 Ecoboost & max tow (Gone)
2021 Silverado Custom 2500HD
2018 Catalina TH26 Toy hauler
30 REPLIES 30
dodge_guy
myredracer wrote:
Drill holes in the siding? OMG, that's like standing at the edge of a tall sheer cliff and getting that terrible feeling in your stomach. Why create a potential opportunity for water intrusion? I'd go with tape and sleep better...
I`ve had more leaks from the factory sealant than from any of the holes I drilled in my trailer!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
dodge_guy
Predrill and use some sealant in the holes and around the back of the holes on the level. Don't use silicone caulk. use some type of rope type sealant. then put a bead of dicor around the top and sides of the level.
Wife Kim
Son Brandon 17yrs
Dog Bailey
SoundGuy
cliffy49 wrote:
I don't profess to be an expert, but I don't think a couple of 1/4" holes, properly sealed, should be a problem.
The point is - why drill any holes and take a chance when adhesive tape works just fine? :h
2012 Silverado 1500 Crew Cab
cliffy49
I don't understand the problem with holes in the unit, I realize that these are not the same vehicle but back in the early 80s I had a custom van. Cut 2 holes in the roof for a sunroof and a 14x14 vent, 2 more in the side walls for port hole windows. Owned that vehicle for 10 years and it never leaked a drop. That van saw more of the states than I will ever see with my trailer.
I am not saying this is what I am going to do but my feelings are that if you take your time and make sure you seal everything properly you should not have a problem. I don't profess to be an expert, but I don't think a couple of 1/4" holes, properly sealed, should be a problem.
cliffy49
BizmarksMom
2edgesword wrote:
Anything big enough for me to see from inside the truck is too big :). I use the small ~2" level indicators and located them on the driver's side corner of my TT (front and side). If you clean the area on the trailer where you're going to place them (alcohol pad) they should stick and never come off.
Seriously? I get the front to back level being small - you are outside finagling that with the jack. But the side to side? I love the fact that I can see that beautiful big bubble in my mirror. Then again, I usually am doing this solo.
2019 F350 towing a Nash 22H
Bigbird65
I used a piece of 1/4" plywood. Fortunately two screws on the black transition molding were long enough to mount the plywood. I used small strips of Gorilla tape to build up the molding below the two screws so that the plywood would be vertical. Very easy to see through the driver side rear view mirror.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
2edgesword
GrandpaKip
LOL. I’ve added at least a dozen holes including a few in the roof.
Even took a jigsaw to the siding to make a hole for a hatch on a previous camper. But then, I tend to shy away from tall, sheer cliff edges.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Bears_Den
I have two, they are both held on by the tape that came with them. 4 years now and still going strong!
2014 Kodiak 279 rbsl
2017 Ford F-150 King Ranch V8
Equalizer hitch
Ford integrated brake controller
2004 Travel Lite 23S Hybrid Travel Trailer ( previous trailer )
1998 Viking Popup ( previous trailer )
No substitute for experience
myredracer
afidel
cliffy49 wrote:
BobbyvCOLO wrote:
I use the LevelMate Pro and the Anderson Leveler Chocks and they work great. Do a google search on the LevelMate Pro and check out the videos.
Since I don't have and don't plan to get a data plan, this is not the type of unit I would purchase. I am not saying this is not a good unit to purchase, it just does not fit into my way of doing things.
Thanks for the advice but I must pass on this now.
No data plan needed, Bluetooth is a local network.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
sgfrye
x2 on the level mate pro
when i pull into site i can see how off level i am side to side by 1/4 inch increments before i get out of truck, i have multiple height wooden boards so don't have to guesstimate
and it "remembers hitch height also.
if you don't have or plan on getting a phone with "blue tooth" capability then no its not for you, however you dont use any data with
it
BizmarksMom
mobeewan wrote:
Or 3M Super Strength Molding Tape. Used for auto body trim and moulding.
This is the stuff I used to mount my level. It is not moving.
cliffy49
cliffy49
