Leveling truck
Manfred
I'm going to make my own "stable loads" to save a few bucks. I have a 2000 f250 carrying a 850SC Northstar PU. I will be pulling an 18' aluminum boat. I want to level the truck when loaded. Will placing a wedge in the lower overload springs -only- level the rig? I have both upper and lower overload springs. Thanks
2005 Northstar 850SC
2016 F250 6.2L
6 REPLIES 6
Richandtd
Why not just add a couple extra springs to each side. If you shop around that should only set you back roughly $500.00 but would have excellent control. I did that on my 98 Tacoma when I put on a heavy duty contractors aluminum large cap which I installed in 2000 and still own and it drives great. I have not done it to my ram yet but will this spring.
2007 Ram 3500 DRW 5.9 diesel 4x4 Bilstein shocks and steering stabilizer
Torklift tie downs
1998 Fleetwood Caribou 11M 3.4 kW generator
Two year old Boston Terrier Yes I'm a dog person
Grit_dog
Nomad III
Nomad III
You're describing an appearance like it's an action. You want to carry extra weight and engage the overloads sooner. If you're already engaging the uppers then yes, engaging the lowers sooner will help with sag, and sway.
My 2500 Dodge doesn't have upper overloads like the older trucks and no holes in the lower spring to easily attach a wedge or stable load.
What I plan on trying this year is using plastic felling wedges on the lower leaf. They match the angle between the leafs pretty closely and are about the right thickness.
To attach them, you can screw/bolt them through the hole in the spring. I'm considering dado ing a groove in the wedge and hose clamping them to the spring leaf. If it still spits out the wedges then maybe grind a slight "catch" in the leaf to keep the hose clamp from sliding.
It's pretty redneck, but for the little I use the camper, if it works, it's a cheap solution.
Manfred
Thanks for the replies. I have the upper bumper stops so I like Towpro's suggestion - decent price. I thought I read somewhere blocking the lower spring will level the truck and the upper overload smooths out the ride/decreases sway. I'll experiment by putting a pressure treated 2x4 wedge between the lower spring, load camper and see how it looks/rides.
2016 F250 6.2L
harley4275
I have a 2500 that only have lower overloads,and put hockey pucks as spacers. full one on the bigger opening at the rear and 1/2 one at the front. screwed in with short thick lag screws,thru the hole in the end of the spring. worked great.
2013 Sunset Trail 25RB TT
2015 Silverado 2500HD 4x4 6.0 l gasser.
Equilizer 4 pt
From Belle River, Ontario
2003 Mountain Star 890sbrx Truck Camper
towpro
if you have upper springs that hit a perch on the frame as your loaded, check out these. http://www.amazon.com/Energy-Suspension-9-9109G-Heavy-Duty/dp/B000CN5GRC
I ran them on my 2006 Dodge, and they were still holding up well at 60K and 9 years when I sold it to my brother.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
kohldad
I have always heard upper first.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
