Mar-13-2023 08:17 AM
Mar-22-2023 12:51 PM
Grit dog wrote:In the lead-cell world, I agree.
^ Are single stage battery chargers of any flavor a thing anymore? Whether talking converters, typical automotive chargers, marine chargers or small power equipment chargers/maintainers…
Every charger I’ve bought for the last 20lbs years has been a smart charger (well except the WFCO, it’s the Dollar Store of battery chargers and it came with the last RV I bought and it purports to be a smart charger as well. It’s just learning disabled…hence the recommendations here to get something else).
Mar-21-2023 05:17 PM
Mar-21-2023 10:09 AM
3 tons wrote:
Converting to an expensive LFP then trying to get by with a marginal charger seems a bit odd to me…However, regardless of one’s charger method of choice (lots of options here, including attended CV/CC* charging - solar or shore, what I do…), rather than the impulse towards new hardware, a better plan would be to start out with an basic understanding of LFP charging parameters, then develop a ‘best practice’ strategy that works best for you - in the end this might even suggest an unattended plug and play charger…JMO
*(constant current, constant voltage)
3 tons
Mar-21-2023 07:55 AM
Mar-20-2023 08:47 PM
Ranger Tim wrote:What does the usage look like?
Interesting to read these responses. Not doing anything yet until I get more info (and money).
Mar-20-2023 07:41 PM
Mar-19-2023 09:55 AM
Mar-19-2023 08:40 AM
otrfun wrote:Ranger Tim wrote:It's unfortunate you have a WFCO. Even with significantly discharged batteries, they're notorious for rarely charging in the higher voltage bulk mode. They tend to stay in 13.6v absorption mode, which increases charge times. The WFCO you currently have will safely charge a 12v lifepo4 battery to 98-99% SOC at 13.6v. However, it'll take much longer to do so vs. a converter with the same current rating charging at 14.4v or 14.6v.
I just want to switch from lead acid to lithium, not upgrade wires and everything else. Finding a new replacement board for my WF-8955PEC seems to be complicated. Straight 14.6V continuous boost single phase vs. 14.6 boost and 13.4 idle dual phase approach, some have a switch for LA/Li, others are auto sensing, still others are Lithium only. Huge range of prices indicates there may be some poor quality fake/unauthorized parts out there. I don’t want to replace the entire thing, just the converter section.
Reading forum posts from many sites usually ends in discussions that go into the weeds quickly. Can anyone cut through it and keep it simple?
You may want to look at the Powermax PM3 MBA series converters. They're designed to be a plug and play replacement for the lower tray 8900 series converters that are used in many WFCO power centers. They're lifepo4 compatible and can be switched to operate in either a single-stage (power supply) mode or a standard 3-stage charging mode. The single-stage (power supply) or 3-stage bulk mode voltage can be adjusted from 13.0 - 16.5v. Since there's always ongoing debate about the optimum charge voltage for a 12v lifepo4 battery, this feature allows you to accommodate whatever lifepo4 charge voltage happens to be the "best" this week, next month or next year.
Regardless which brand converter you eventually decide on, highly recommend *not* purchasing a single stage 14.6v converter. If you inadvertently float a 12v lifepo4 battery at 14.6v (100% SOC) for long periods of time you may risk damaging the cells. Purchase a 2-3 stage converter. A 2-3 stage converter will always decrease charge voltage (go into absorption/float mode) so you never have to be concerned about overcharging and damaging the cells. Your expensive lifepo4 battery will thank you.
Mar-19-2023 08:28 AM
Mar-19-2023 08:21 AM
Sure.
This one: https://www.amazon.com/gp/product/B07DP3J3FD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Remove old, replace with new. Plug and play. 14.4 volts max charge.
You're done.
Mar-19-2023 06:23 AM
Mar-18-2023 11:24 AM
Mar-18-2023 07:58 AM
Grit dog wrote:Ranger Tim wrote:
WFCO makes an auto-sensing replacement kit that is two stage. I think I’m gonna order it.
Don’t. Unless you know something about WFCo we don’t. Traditionally they are borderline junk.
Mar-17-2023 09:09 AM
Mar-17-2023 08:47 AM
pianotuna wrote:
Ranger Tim,
14.6 is right on the edge of too much. 14.4 volts may increase life span.
