Sep-29-2018 11:09 AM
Sep-29-2018 08:53 PM
Wharfcat wrote:
What's your opinion on brake systems to flat tow the CRV. Seems pretty light.
Sep-29-2018 05:51 PM
mountainkowboy wrote:Wharfcat wrote:
So the topics I'll be researching are a spacer for the bed, tie down arrangement, the electrical connection in the truck bed and how I can flat tow my 2013 Honda CRV.(and a thousand other things.)
Thanks to all in advance!
1.) I built mine and attached it to the bottom of the TC so I don't have to handle it...it's always there. Also either do a spray-on bed liner or rubber mat under the TC's. It helps in keeping it "planted" on the truck.
2.) Tie downs are either Happijac, Torklift, or Stablelift. I've got Happijacs on mine, but will be going to the rear Torklift system that works with my hitch.
3.) I have a round 7 plug mounted in the bed of the truck just for the TC, but you can get a cord to plug it into the rear round 7 for your truck.
4.) Torklift and Reese make a special hitch that's designed for TC's and it uses a "stinger" to get the ball behind the TC. I have a Torklift and tow behind it regularly. We have a 2006 CRV and it tows fine behind us when we take it.
Hope this helps......
Sep-29-2018 05:00 PM
Sep-29-2018 04:59 PM
Sep-29-2018 03:47 PM
Wharfcat wrote:
I had a stinger for my other truck and I only pulled a light boat or small utility trailer, 2 inch if I remember correctly. I think the Reese is 3 inch IIRC which the new truck will have. Would you go to the extra expense of the Torque lift hitch with just the CRV? Google says the CRV weight 3500lbs?
Sep-29-2018 03:38 PM
Wharfcat wrote:
Does the foam help the rigidity of the riser or is that just to provide insulation to the bottom of the camper?
Sep-29-2018 03:15 PM
Sep-29-2018 03:08 PM
Sep-29-2018 02:42 PM
Sep-29-2018 01:34 PM
Sep-29-2018 12:24 PM
Sep-29-2018 11:31 AM
