Looking for recommendations on a two bike rack
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
โJul-11-2022 08:05 AM
Has anybody got experience with any of these?
Is there any particular brand and model that is best or most suitable for this application?
Anything I should be aware of before I buy something?
Thanks, Joel
- Labels:
Truck Campers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โAug-21-2022 01:17 PM
Hemi Joel wrote:
I could triangulate the mounting of the bike rack with ratchet straps going from the center of the rack out to the corners of the truck to keep it stable, either on the front or the back.
I double this advice from Hemi Joel. I have a nice Yakima rack mounted in my rear tow hitch extension in back of the camper and the play up and down was too much and tries to launch the bikes off the rack. Almost lost one kids bike first time out with it. Tie down straps to the jacks in the back fixed it.
Used a ladder rack for a while till it broke the ladder. Mine is very light aluminum. Had to insert 1/2" copper pipe into ladder pipe and drill and screw down. Used generous amounts of JB weld where it attaches to the rung of the ladder. Just too much inertia when hitting dips or mild off road.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โAug-21-2022 11:11 AM
covered wagon wrote:Grit dog wrote:Hemi Joel wrote:
Maybe I'm wringing my hands over nothing, but these Schwinntech slides are known for problems. My ladder is mounted on the rear slide. I just don't like the idea of hanging a couple hundred pounds on it and having it bounce up and down for thousands of miles, possibly stressing the slide components.
Couple hundred lbs is a different story.
Our Mountain bikes are maybe 30lbs each?
I still would not want to trust the rv ladder. That thing is typical hollow parts and smaller size screws that rust. I think you would be much safer with a welded steel bike rack. Always locked and easy to adjust the way you need it.
Lol. Is this just on a hunch, or because the tubing is hollow?
Being mounted to a slide out could possibly put some stress on a โmoving partโ although if itโs designed to be climbed on then also not likely. (With lightweight bikes, not โa couple hundred lbsโ. )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โAug-19-2022 09:44 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โAug-16-2022 05:01 AM
There are waterproof covers for bikes when traveling to help in keeping them clean, just make sure they are tightly wrapped around the bike to keep from getting torn.
Ebikes are very heavy compared to others, upwards to 65lbs. Something to think about when traveling.
This trip was our first time out with two ebikes. I first mounted on the Jeep along with the watercraft trailer. Man was that to heavy for the Jeep. After some thought I mounted them between the truck and Jeep. I used a GEN-Y GH-404 offset dual receiver hitch along with a 6in raise for the Jeep tow bar and a 4in raise for the 1up super duty bike rack. I can still get into the camper using the Fox landing.
2013 RAM Crew Cab, 3500 4x4
2019 Arctic Fox 1140 wet bath
Old
2016 Eagle Cap 960
2004 Jayco Talon ZX
1998 GMC Suburban with a Cummins 6BT conversion.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-19-2022 09:15 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-18-2022 04:31 PM
https://www.amazon.com/MBP-Alloy-Release-9x100mm-Storage/dp/B07MDXZGMB/ref=sr_1_3?crid=2IM1Y060167SW&keywords=bike+skewers+mounts&qid=1658186842&sprefix=bike+skewers+mounts%2Caps%2C74&sr=8-3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-18-2022 11:02 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-15-2022 03:36 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-15-2022 01:31 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-15-2022 01:05 PM
JoeChiOhki wrote:covered wagon wrote:JoeChiOhki wrote:
Here's my review on a swing away two bike locking hitch based bike rack that I used in the past with my camper:
New Swing away Bike rack for Behind the Camper
Matt, mine swings the bikes out and around the corner of the camper to the side. I got a new Yakima swing away for 300 bucks because only the carton was damaged. I get lucky once in awhile.
Yup, I paid $225 new at the time I bought it back in 2012, that one ironically is only about $60 more new than it was then, and its an American made bike rack, which is impressive for the price.
I still have it, and am planning to likely modify it to extend the length of the swing arm a bit to allow it to completely swing away from the rear of the camper to allow the snap-n-nap bed to extend.
I had a fabricator modify mine so both bikes would go around the corner of the camper instead of just the one. For some reason bicycling in the mountains seems easier and more fun.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-15-2022 10:09 AM
Grit dog wrote:
3 pages of expensive ideas when a $79.99 ladder bike rack would work?
I tried a ladder rack and it absolutely did not work with our modern mountain bike frames.
It was very intrusive, too, as we regularly use the ladder to access our roof racks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-15-2022 09:54 AM
The ladder is mounted to the rear slide and uses the large diameter tubing. Heavier e-bikes are not an option with a ladder rack and even hanging regular bikes off your slide really is not advised.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-14-2022 12:17 PM
CB
Channel 17Redneck Express
'1992 Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles
'1974 KIT Kamper 1106 - 11' Slide-in
'2006 Heartland BigHorn 3400RL
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-14-2022 09:23 AM
