Lp detector problem
RooDude09
We bought our 2010 keystone hideout new in 2010. We've always had a problem with the Attwood lp detector chirping once and the LED going solid yellow. If not reset it will beep again in about 30 seconds. The manual says it is a processes error. A few years ago after a few try's with the dealer we got it to do it and they replaced it but it still continues to do it. It always happens when when go to cook at the nearby stove. Has anyone had a similar problem? This beep about gives my small dog a heart attack every time it happens..
8 REPLIES 8
DE88ROX
had the same issue this summer. took in to have it looked at. they did a drop test. system held 8lbs steady for 15 minutes. They couldnt find anything wrong with the the system.
It has gone off before while my daughter was spraying hair spray and one other time while the oven was in use.
my Starcraft is a big POS anyway so who knows.
[COLOR=]TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
dtzackus
Our damn LP detector was going off, it seem to wait till 4am. I just got rid of it, I called for a replacement and it was $120 with the same 1 year warrenty as ours had.
Dan, Tammy, Cory, Leah and Adam
2016 Chevy Silverado 2500HD 6.0
2018 Highland Ridge Open Range OF374BHS
GM Integrated Trailer Brake Controller
RedRocket204
Wind River wrote:
Are your batteries fully charged? Low voltage will cause the detector to chirp.
Yes. I will also add a problem I found with mine after purchasing a 3 year old used TT.
Previous owner: Some liquid soap had spilled just behind where the LP detector was installed in the kitchen cabinet. Since it did not appear the soap was ever cleaned up, the soap proceeded to corrode the wire connections at the LP detector. Jump forward to me having an issue with the LP detector periodically going off.
When I removed the detector to inspect it, one of the wires was only held on with a few wire strands. The few wire strands that remained was not even close to allow the proper AMPs to flow to the detector, causing an issue where the detector would periodically go off but did not indicate LP detection. I cleaned up all of the liquid soap and then re-spliced the connections and have not had an issue since.
Point of the story is yes, low voltage will cause a LP detector to periodically go off even without LP detection. I believe the manual states low voltage will cause this occurrence.
I love me some land yachting
Crazy4gsds
We had the exact same issue happen with us and the only thing I can contribute it to is that we didn't have one of the valve connections seated tightly to one of the LP tanks. The dealer couldn't replicate it nor could they find a gas leak once they tightened it. The next trip out which was this past weekend (9/12) it chirped once and yes it's loud and about gives you a heartattack. I reset it and was quiet the rest of the trip.
2011 CruiserRV Viewfinder 27RBSS
2012 Ford F150 Platinum 4x4 SuperCrew EcoBoost
Frannie our dark sable German Shepherd furkid
Fritz our red sable German Shepherd Dog gone but never forgotten
Darby our black/tan German Shepherd Dog gone but never forgotten
Wind_River
2019 Ford F250 XLT Super Duty 4X4 6.7 Power Stroke
2004 Jayco Jay Flight 25RKS
Equal-i-zer Hitch, 3502 Ultra Fab Tongue Jack
Twin Honda 2000i w/parallel kit
Dick_B
An easy way to check for leaks is to shut off both LP tanks and watch the green/red indicator. If there are no leaks the indicator will show green and stay green.
If there is a leak it will show red in just a few minutes. If that happens one has to find the leak using various methods; leak detector or soapy water.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
hddecker
There is a shelf life on detectors and it varires by tpye. If I remeber it's five years for LP.
The dealer tried to slide that by me but it didn't work, the LP detector in our rig was alreay well into the second year.
sbowman871
Sounds like you might actually have a leak. You mention, "when you use the stove". LP gas is much heavier than air. The gas lines are going to be close to the floor. Would suggest a pressure check on your system. Might try and borrow a portable gas detector to verify. Many safety supply stores and some large distributors such as United Rentals ( trench division location) rent them.
2010 Everlite 29FK
2011 Ford F150 V6 Ecoboost Max Tow 3.73
Parkit 360
