LPG Hot Water tank pop-off valve erupted - is this normal?
Sauropod
Hello! I looked through the forums but didn't find exactly my situation. We are first time pop-up owners (2009 Starcraft 2406) and I took it out for an extended adventure the last 5 days. I fired up the hot water heater in order to try out the shower. Though my intent was to use the shower within minutes of firing it up I was delayed by a photo-opp with an elk :-). About 10 minutes after lighting the hot water heater the pop-off valve did its thing and water was pouring out of the external vent. I carefully turned off the hot water heater. The upside was the shower's water was, indeed, hot-hot-hot. I used it again 2 days later but this time I made sure to shut off the flame as soon as I was done with the shower.
Here is my question: On a 2009 Starcraft 2406 (or any other pup w/ LPG water heater) must I light it, use it, then shut it off immediately? I was under the impression it was like the water pump that auto-pressurizes as needed. I presumed once I lit the hot water burner that, if it became too hot, it would back off the heat or shut down completely. However presuming isn't knowing ๐Ÿ™‚ thus my coming here. Before I left I put in a new pop-off valve, new thermocoupler and new element as they were all original and I didn't want any troubles like I had with my initial voyage which saw the factory converter go bad (thanks WFC for the easyish-to-install replacement!).
10 REPLIES 10
pojv
You may find that replacing the whole water heater is not much more than replacing the thermostat unit and is much simpler. I just replaced mine, the heater water 270.00 delivered to my door, it took 2 hours to replace.
You can PM me and I will provide you a link from an individual that did replace just the thermostat unit.
Phil
07 Starcraft 3612 w/ 4 Inch Lift kit
05 Dodge Dakota 4X4
Polaris Hawkeye
Sauropod
Thanks for the link! Pricey little gadget vs the pop-off valve on its own.
At least I know I wasn't wrong in my initial presumption. Thanks everyone for the help!!!
Old-Biscuit
Pressure/Temperature Relief Valves on water heaters are NOT a one time device.
There is no wax to melt and opening does not make them useless.
They operate on temperature (210*F) and on pressure (150#....typically close when pressure drops below 125#)
They have a lever that can be operated to manually open them. Spring loaded snap shut.
Exercising them via lever once a year is a normal test.
OP:
The gas control/thermostat are one complete unit.
This should work on your 2009 year model....check the gas inlet/outlet size.......LINK
ScottG
You'll also have to replace the TPO valve (the thing the water came out of) because once they are tripped and the wax inside has melted, they're junk.
Sauropod
That is the exact one I have!
So if I am reading you correctly I'll need to replace the entire gas control unit as the thermostat itself isn't replaceable as a separate item.
Any recommended places to purchase? I did a check for sit 610 ac3 online and Google didn't do its normal "here are 30 vendors selling it". Does it go by another name?
I suppose in the interim I can run out and turn it off within 7 minutes or so. Makes for fast showers that way which isn't a bad thing on a 5 gallon tank. ๐Ÿ™‚
Old-Biscuit
Sauropod wrote:
Thanks everyone for such quick replies!
It is a Suburban and on the control's top it says "sit 610-AC3". It has a black knob that says "off, Pilot, On" and then in the center it has a selector that lets me pick one of five temperature settings, "High, Medium, Low" with notches to either side of medium. It overflowed whilst on Medium.
We replaced the thermocoupler originally because it wouldn't light and, once we replaced it, it lit no problem.
Looks like this? (Sorry pix upside down)
The 'probe' sticking out the back (with the white cover around it) THAT is the thermostat. Gas control screws on/in tank and the thermostat protrudes into tank into the water.
Yours is bad...........not controlling.
Gas control unit has to be replaced.
Sauropod
Old-Biscuit
Your T-stat has failed.......it should have shut down gas operation when water reached temp setting.
What Brand/Model of water heater?
Is it one that has temp setting on gas valve? Pilot light?
If so........you need a new gas valve as the thermostat is part of gas valve.
ALL models have t-stats to control temp.
bondebond
You are correct in assuming that it should shut down the burner when the desired temperature has been achieved.
My first impression is a faulty TPR valve. If replacing that (one of the cheaper options) doesn't fix it, then I suspect the thermostat control module may be bad.
Is it an Atwood or Suburban? If it is an Atwood, look at the Atwood Mobile Service Manual for assistance in troubleshooting and replacements.
I would not think it is the thermocouple as that would prevent gas from ever getting to the main burner if it could not detect heat coming from the pilot.
This space left intentionally.
2006 Fleetwood Sequoia and mods...one of the tallest highwall pop-ups on the planet after flipping the axle.
TucsonJim
Here are a few things to check. I'm sure others will speak up also:
1. The pressure relief valve has malfunctioned and is releasing at too low a temperature. I'd change this out because it's cheap, easy and can be found at most hardware stores.
2. Thermocouple malfunction.
3. Shut off circuitry malfunction.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
