I might be wrong but I believe you would almost need a donor truck for all the parts it would require. Computer, wiring harness, shift linkage, brake pedal, transmission coolor, transmission cooler lines, flywheel, torque converter, transmission, drive shaft, transmission support bracket, steering column with shifter, ect.
Like others have said would be cheaper and easier to trade trucks.
