Sep-01-2015 04:50 PM
Sep-05-2015 03:05 AM
Sep-04-2015 07:50 PM
Sep-04-2015 07:30 PM
TomG2 wrote:Why the anger? Drink your coffee and lighten up.Huntindog wrote:
....snip........ :B
I haven't tried this yet, But if I were to take a rectangular box, and hold it out the window on the highway in different positions, then that would be a pretty good test of my thoughts. I think I know what will happen
When you start playing around with your boxes, don't forget to place one in front of your simulated travel trailer to take the place of a tow vehicle that is punching a hole through the air. Also, include a roadway that will affect the airflow around the two vehicles. There about a hundred other factors to consider if you want a really scientific evaluation. In fact, they have such a thing and it is called a wind tunnel.
Sep-03-2015 05:34 PM
GrandpaKip wrote:lbrjet wrote:
Nothing wrong with thinking.
Especially around a campfire.
Sep-03-2015 11:34 AM
Most TVs nowdays have spoilers or air dams to keep the air passing under them to a minimum.
Sep-03-2015 08:22 AM
Sep-03-2015 04:39 AM
Huntindog wrote:
....snip........ :B
Sep-02-2015 10:47 AM
Sep-02-2015 06:26 AM
Sep-02-2015 03:00 AM
Sep-01-2015 08:27 PM
Huntindog wrote:For virtually all TT front-end shapes, there will be a negative pressure resulting from air flow over the front of the roof.
---If it is tounge low, then the roof of the TT will act like a large spoiler creating downforce... I know it's not much of an angle (usually) but it is a very lage surface, and wind speeds can easily exceed 100MPH when towing into the wind.
So how much downforce would this add? Would it be enough to exceed the weight ratings of axles and tires? Especially since the industry tends to skimp on these components?
Sep-01-2015 08:26 PM
TomG2 wrote:
The effect you are asking about is totally about aerodynamics and the application of Bernoulli's principle. I am thinking that there would be a slight amount of lift involved with a lowered front face, just as there is in an airplane wing. The kicker is that the drag associated with towing a travel trailer makes looking for other changes tiny in comparison.
Sep-01-2015 07:08 PM
Sep-01-2015 07:02 PM
