YC 1 wrote:
It is not unusual for fuse boxes to need replacement. The contacts can become resistive which can then lead to heat and ultimately a slow disintegration of the box.
x2
I personally have repaired two bad fuse boxes for friends. In both cases, a bad solder joint on the fuse connector mounted on the PC board was the culprit. It would cause enough heat to melt the fuse.
It wasn't an issue with over-current which would then pop the fuse, it was an issue of poor workmanship, leading to a bad connection, which then of course meant circuit failure with the fuse still good.
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
