minimum tire pressure for non towing.
peaeye1
This question is on a 2016 F350 superduty Dually. The tires are LT245/75R17E Goodyear,s.Due to the stiff suspension, I would like to reduce the tire pressure to a safe, but more comfortable ride.when not towing. I run 65 rear and 75 front.per Ford's recommendation's when towing.I have looked for a load chart for these tires, but have had no luck.The truck weighs out at 5260 front, and 4280 back.I have a aux tank and carry extra fuel. I will be making a non towing run of about 1300 miles in a few days and would like some info on the minimum PSI I could safely run in these tires on this upcoming trip.
Thanks
2016 Ford F350 Superduty Dually Diesel, long bed.
40 ft Winnebago Destination.
30 REPLIES 30
Atlee
The door sticker for my F150 4x4 w/ HD Pkg calls for 55# front and 60# in the rear. I don't change the air when I'm pulling. The OEM tires are LT245/75R17 LRE.
Erroll, Mary
2021 Coachmen Freedom Express 20SE
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
Equal-i-zer Hitch
Cummins12V98
Me Again wrote:
35 pounds in a dually empty will improve ride a lot. On RAM 3500's the tire pressure indicator system does not alarm. Chris
I run 80 front ALL the time, rear 65 loaded at max RAWR and 35 solo rear.
40K on these.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
FishOnOne
I wouldn't run less than 60 psi on the front tires. Anything less and tire wear seams to dramatically increase from my observations.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Me_Again
BigToe wrote:
The previously provided (and excellent) link above is produced by Toyo. For an equivalent document produced by Goodyear, see:
https://www.goodyeartrucktires.com/pdf/resources/publications/2010_loadinflation.pdf
The load inflation tables have the same values for the size you mentioned, but in case you wanted assurance from the manufacture of your specific brand of tire, you have a resource now from Goodyear.
Inflation tables are standard across the industry for auto and truck tires for any given size. Now with ST trailer tires the rules are all being thrown out the door.
Chris
BigToe
peaeye1
ChooChooMan74 wrote:
Load Inflation and Tire Info PDF File
This is my favorite Load Inflation Chart on the internet.
Thanks, this is a great chart, some very useful info.
peaeye1
Me Again wrote:
peaeye1 wrote:
Me Again wrote:
Why so high in the rear, hardly worth the trouble.
I would put the fronts at 65-70 all the time, run 35 in the rear empty and 65 when towing.
No trouble to me.....but then my life is not a hectic as some. I just want to find a PSI for hi speed non towing, interstate running.
6440 pounds of capacity on the rear axle at 35 pounds inflation, or 2 X + what you need. And you are worried????? Chris
I am not worried about weight, just do not want any heat buildup with to little PSI at high speed long runs.Just calm down:R
Me_Again
peaeye1
ChooChooMan74
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
tvman44
I run my rear tires the same as the front for non towing, much better ride. 🙂
Papa Bob
1* 2008 Brookside by Sunnybrook 32'
1* 2002 F250 Super Duty 7.3L PSD
Husky 16K hitch, Tekonsha P3,
Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540
"A bad day camping is better than a good day at work!"
JIMNLIN
My old '98 3500 DRW crew cab 4x4 454 weighs 3340 on the rear when empty. Thats just over 800 lbs per tire.
Tires are non OEM LT235/85-16 E so I keep them at 35 psi for a much better ride out here on gravel and chip county roads.
Me_Again
peaeye1
SoCalDesertRider wrote:
With a diesel, 65 front and 45 rear is quite safe unloaded. Could go as low as 50 front and 35 rear, but that's pushing it, in my opinion.
According to the chart I think I will go with 60 front and 55 rear when not towing.
Thanks to all for the info.
