โAug-04-2016 09:39 PM
โAug-08-2016 03:29 AM
โAug-07-2016 04:26 PM
Me Again wrote:
35 pounds in a dually empty will improve ride a lot. On RAM 3500's the tire pressure indicator system does not alarm. Chris
โAug-07-2016 02:48 PM
โAug-06-2016 08:34 AM
BigToe wrote:peaeye1 wrote:
This question is on a 2016 F350 superduty Dually. The tires are LT245/75R17E Goodyear
The previously provided (and excellent) link above is produced by Toyo. For an equivalent document produced by Goodyear, see:
https://www.goodyeartrucktires.com/pdf/resources/publications/2010_loadinflation.pdf
The load inflation tables have the same values for the size you mentioned, but in case you wanted assurance from the manufacture of your specific brand of tire, you have a resource now from Goodyear.
โAug-06-2016 07:08 AM
โAug-05-2016 05:32 PM
ChooChooMan74 wrote:
Load Inflation and Tire Info PDF File
This is my favorite Load Inflation Chart on the internet.
โAug-05-2016 05:22 PM
Me Again wrote:peaeye1 wrote:Me Again wrote:
Why so high in the rear, hardly worth the trouble.
I would put the fronts at 65-70 all the time, run 35 in the rear empty and 65 when towing.
No trouble to me.....but then my life is not a hectic as some. I just want to find a PSI for hi speed non towing, interstate running.
6440 pounds of capacity on the rear axle at 35 pounds inflation, or 2 X + what you need. And you are worried????? Chris
โAug-05-2016 04:21 PM
โAug-05-2016 02:17 PM
โAug-05-2016 01:10 PM
โAug-05-2016 12:44 PM
โAug-05-2016 12:23 PM
โAug-05-2016 12:14 PM
โAug-05-2016 10:29 AM
SoCalDesertRider wrote:
With a diesel, 65 front and 45 rear is quite safe unloaded. Could go as low as 50 front and 35 rear, but that's pushing it, in my opinion.
