Jun-22-2015 08:58 PM
Jun-27-2015 02:09 PM
Boondoc wrote:
You should just hook up a permanent sewer hose to your outlet pipe. Then you will preserve your ability to move it.
Jun-24-2015 11:27 AM
Jun-24-2015 06:43 AM
djgarcia wrote:
Modifying the plumbing---
With tounge in cheek, this sounds like "amputating a foot because you have a hang nail" :):):)
Jun-24-2015 06:31 AM
Jun-24-2015 03:27 AM
swimmer_spe wrote:samhain7 wrote:
It's a campground that will let you dump your grey water on the ground?
Wow....
Anyway, if they let you, I would tend to agree with leave the vents and gut what you don't want.....
What do I do about those pesky little vents for the vent pipes? Leaving them as is will mean that the mosquitoes will visit me. I could throw some screening up.
Jun-23-2015 07:14 PM
Jun-23-2015 06:46 PM
djgarcia wrote:2012Coleman wrote:
I can't imagine living in a TT where the gray water is just dumped to the ground underneath it. That's going to be some cesspool after a while. Good luck with it.
X1, gray water dumped on the ground under the trailer will end up stinking and creating bad orders inside your trailer! If you are determined to dump gray water under the trailer, then strongly suggest you drain into a pipe i.e. PVC which dumps at least 20' away from the trailer, like a leach line in effect.
Jun-23-2015 06:28 PM
Jun-23-2015 02:03 PM
Wow....
Jun-23-2015 01:27 PM
Jun-23-2015 12:51 PM
samhain7 wrote:swimmer_spe wrote:
As for a bathroom, I am right next to the outhouses.
There are outhouses?
Where is this trailer located? Campground? Private property?
Jun-23-2015 12:22 PM
Jun-23-2015 12:19 PM
Jun-23-2015 12:17 PM
swimmer_spe wrote:Old-Biscuit wrote:
So no bathroom facilities......ie: bathroom sink, shower or toilet :H
Might want to explain in more detail what it is you are trying to achieve.
Cause it sounds like so far just a kitchen sink dumping on ground and no other facilities.
That is exactly what I want. I do not want or need a bathroom. On my trailer, it takes up a good chunk of space, and the trailer has no bedroom. I have to pull out the couch to sleep. I figure if I turn the bathroom into a bedroom, I will sleep better. As for a bathroom, I am right next to the outhouses.
So, once I am set up, the kitchen sink is the only drain to deal with, and I want to just put it to the ground.
