Moving spots at RV park ? about weight distribution
OregonMan
Hi guys so I have to move to a different spot today at the RV park. My trailer is relatively light weighing less than 5,000 lbs. Should I attach the weight distribution bars when moving spots, or is it okay to just use the ball hitch? I was planning on staying hooked up overnight as well. Thanks for any tips.
7 REPLIES 7
Draggo
I wouldn't worry about it just to move around the park. I used to store my TT about a 1/2 mile from the campground and since it was an old country road where I could go slow I would just drop it on the ball and never had a problem. This was with a heavier TT (about 7K) and 1/2 ton pick-up (not the one in my signature).
Mike & Company
2021 GMC Sierra SLE (6.6L V-8, 3.73 rear gear)
2018 Coachmen Freedom Express 279RLDS
Reese W/D & HP DC
Lwiddis
I think you'll be fine without the WDH.
JIMNLIN
For that small trailer moving a few campsite down there is no need for the bars or even to have a the WD system hitched up for that short move.
valhalla360
Nomad III
Nomad III
We've done it from time to time...
I'm assuming you are tooling around the park at 5mph, so most of the reason for a WDH goes away.
Even if it leaves you slightly over the carrying limit, I wouldn't worry too much. That's largely controlled by hitting a big bump at high speed...at 5mph, the dynamic forces will be nothing close to those at 60-70mph.
Do be careful to think things thru. It's really easy to mess something up when you aren't following your normal process.
Correction: I missed the part about staying hooked up...put the bars on. Nothing saved by not and one less thing to forget in the morning.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
mleekamp
Agree with ktmrfs. If not on the highway, and just moving short distance at 5 or 10mph, no bars needed. But if staying hooked up overnite (you don't mention if leaving next day or ?) I'd just hook them up.
Grit_dog
Navigator
Navigator
Wdh not needed.
But then again, I wouldnโ€™t even own one for that light of a camper behind your newer F150.
ktmrfs
as long as your within the weight carrying capacity of of the reciever, (many recievers have a weight carrying limit that is less than weight distributing) not an issue IMHO. I move my trailer from the RV lot in our neighborhood to the driveway and back w/o hooking up the WD.
2011 Keystone Outback 295RE
