Travel Trailer: 1983 Man-O-War 15'
Where the 120V AC 30amp comes inside (driver side):
Converter Close Up (passenger side, front corner):
Input Current - 3.75 Amps AC
Input Voltage - 120 Volts AC
Output Current - 25 Amps DC
Output Voltage - 12.6 Volts DC
Converter Overhead (passenger side, front corner):
Fuses Closeup (driver side, front corner):
Fuses Overhead (driver side, front corner):
QUESTION #1: Is there an immediate concern?So that fuse box looks pretty corroded. Is that a bad thing? What about the stripped paneling to the top right and left of the fuse box, is that from excessive heat?
QUESTION #2: What is the loose bundle coming out of the right side
of the fuse box? QUESTION #3: Flipped fuse? No fuse? Everything I've tested seems to work on shore power.I have no battery yet. What is the point of this fusebox, is it to prevent over draw from 12V DC items (currently only lights I think)?
QUESTION #4: What is the loose wire (red/yellow) coming out of the converter? Is that for the battery connection?
QUESTION #5: Any idea if a battery will power my AC Outlets or are they shore power only? Miscellaneous Questions:* Any idea what amp fuses those are?
* How do I add a battery?
* Does this electrical look original or custom?
* Am I going to die?
Thank you in advance for your help!
