โAug-03-2014 11:35 AM
โAug-04-2014 03:20 PM
lawrosa wrote:34ft Palomino Sabre 31qbds
Love the floor plan
Hate that it bounces & shakes
I have used the x-chocks on both sides. I have attempted to use stablizer manual jacks on the slide out sides.
It has electric jacks & they stink. Would switching to manual scissor jacks help? Could I install scissor jacks & use both?
I use these jacks from walmart..
I lower the front of the TT as low as it can go then place two jacks on the rear frame.
Then I lift the front up to just above level then place two on the front frame. Then lower.. All four corners are now fully supported..
I get zero bounce and shake. ( I support on Wood blocks )
Camco jacks
โAug-04-2014 02:59 PM
The video would only be realistic for a seasonal sited TT. Nobody is gonna lug all of that along.
As for your suggestion of only using 4 jacks... It is a really good way to bend the frame and ruin the TT. One may get away with it on a short TT with a real stout frame... Other than that, No way Jos'e.
โAug-04-2014 01:50 PM
Doug33 wrote:Ron3rd wrote:
One thing that might help is to use a scissor jack under one of the axles. I have a 35 ft TT and have had the same problem and explored options on the Forest River forum, where I got the idea of the scissor jack there. Seems to be a problem on the very long trailers like yours and ours. The jack helps quite a bit.
Same here. If it's just me and the wife for a weekend I won't bother, but if the whole family goes, I use a scissors jack on the axle between the wheels on both sides and it makes a huge difference. The X-chocks don't work effectively on my TT because it sits so high off the ground and there is a huge distance between the two tires.
BTW - I notice the bouncing the most when I am sitting on the bathroom throne at the back of the TT. When a bunch of people are moving around and in/out of the unit, I feel like I'm on an amusement ride and need to strap myself in. ๐
โAug-04-2014 01:04 PM
lawrosa wrote:The video would only be realistic for a seasonal sited TT. Nobody is gonna lug all of that along.I love Wally's description. Still trying to figure out how that works?
"You can use the stand to stabilize the "spring bounce" that could occur between the front and back of your trailer to help your overall ride feel smoother. You can also enjoy greater stability inside the RV when it is stopped for camping."lawrosa wrote:
I lower the front of the TT as low as it can go then place two jacks on the rear frame. Then I lift the front up to just above level then place two on the front frame. Then lower.. All four corners are now fully supported..
Camco jacks
If you follow this video is exactly how I do it. But I use those aluminum camco jacks at the 4 corners. ( I don't use cinder blocks as this guy talked about.)
You see after you get side to side good you lower the tongue as low as it can go. Put the stands at the two rear corners on the frame. Then jack the tongue up to above level.
Place two jack stands on the front two corners and lower the tongue.
The trailer is now supported by the frame with jacks that do not wobble like the crappy scissor jacks they give you.
Level/stabilize an RV the correct way to prevent any wobble or shake...
โAug-04-2014 12:03 PM
Camco jacks
โAug-04-2014 10:13 AM
Camco jacks
โAug-04-2014 06:25 AM
โAug-03-2014 11:05 PM
โAug-03-2014 09:31 PM
โAug-03-2014 06:22 PM
โAug-03-2014 01:04 PM
โAug-03-2014 12:50 PM
โAug-03-2014 12:44 PM
โAug-03-2014 12:43 PM
โAug-03-2014 12:33 PM
