Narrow Travel Trailers
biohazard
Hi all,
Im looking to get a travel trailer and was wondering if there were any companies that make tt's that are narrower than the standard 96". Ive googled it a few times and keep finding companies that used to make narrow trailers, but cant find anything current. The spot i plan on backing it into on the side of my house is only 1 or 2" wider than 96" I would like a little more room than that.
Thanks for your help!
25 REPLIES 25
gmw_photos
As mentioned, the funfinder's are 7' wide. Mine has a slideout that is about ten feet long, so it makes it very roomy when expanded.
harmanrk
Palimino/Soliare make a line of 7 footers.
Edit: I see I was beaten to that answer.
2017 Ford F250 CC-SB SRW PSD
2013 Solaire 190x
mcmanawayp
Hi!
We own a 2012 KZ Sportsmen Classic 200. It is 90" wide. Great little trailer!
biohazard
APT wrote:
I believe most hybrids are only 7' wide. Palominorv Solaire 7 is also 7' wide.
You may want to rethink only having 6" on each side of TT to back into. That's very tight and I think unrealistic to back into.
yeah, i was thinking its a bit tight, but its the only option. anyone have experience with front mounted hitches? do they help maneuvering in tight spots? Its just going to be the rear 7-8 feet of the trailer that has to get into that spot.
JiminDenver
Amerilites are nice and you rarely hear complaints about them. They do have some weight and cost saving things that people dislike like plastic sinks and osb in the cabinets but they haven't affected our camping at all. It has held up well considering we are usually miles off the beaten path running over washboards, ruts, washouts, rocks etc.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
APT
2017 Subaru Outback 3.6R
limbery
Chalet Takena's are 7' wide and the 1865 model and the slightly larger one each have a 27" slide.
biohazard
Awesome, thank you all, keep em coming. the ameri-lites look pretty good.
dahkota
Cruiser RV makes a couple of funfinders and Shadow cruisers that are 7' wide, and a couple that are 7.5'.
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
boscowtx
Try Apex, our 22qbs is 7.5 ft wide, and has a slide, very comfortable for both of us!
2009 Chevy D max, 4x2, extended cab, SB
JiminDenver
I believe our Ameri-lite is only 7 1/2 feet wide. They are a bit shorter too.
It is a 3 season entry level trailer but we use it when it gets down to the 20s at night.
There are other narrower rigs too.
