Dec-10-2015 10:24 AM
Dec-13-2015 03:54 AM
Dec-12-2015 07:43 PM
Dec-12-2015 05:34 PM
sw20td06 wrote:
Olay after a couple days of searching I think I narrowed my choices to the following.
05 Excursion 6.0 Turbo Diesel 4x4 with 170k, with a 2015 F250 front end. Very clean, and I have a shop lined up to do bulletproofing if I go this route. I love the look of this truck and it is not lifted so I am expecting a better ride than my old lifted 7.3 on 37 in tires.
OR
09 Suburban 2500 LT 4x4 with 119K. Also very clean, but I am worried the 6.0 will be really slow fully loaded with people and pulling the trailer. But I do like the "car" like ride. Interior is leaves much to be desired in terms of quality.
Coming from the 7.3 Excursion I think I am more inclined to pick up another newer model especially with the newer front end. It will cost me an additional 5k to "bulletproof" the motor, but I think it will last a lot longer than the Suburban.
Any advice which route I should go Doing some research, the excursion has some lower payload capacity compared to the Suburban is that correct? Any input would be great!
Dec-12-2015 04:47 PM
Dec-11-2015 05:55 AM
Dec-11-2015 03:17 AM
atreis wrote:sw20td06 wrote:
Thanks for the tips everyone. I ended not getting the Toyota. I had a 00 Excursion 7.3 Diesel which I sold recently. The ride was not comfortable when not towing. It had 37 in tires and a 6 in lift which added to the roughness. It was a great truck but would cost more in the long run trying to improve the suspension, tires, etc. Im thinking of getting a 2003+ 6.0 Bulletproofed Excursion with a 4 link upgraded suspension, but they sell for a premium also and most are modified. I live in CA and smog tests for diesels are mandatory now.
I've test driven the 2009-2011 Suburban 2500. Although I think it would handle the load easily, the interior felt really cheap for the price they were asking. I came from the Excursion, I know which wasn't the "best" interior.
A bulletproofed vehicle is going to have a significantly lower cargo capacity - that bulletproofing adds a lot of weight. (And .. Uh... Do you really need it? Can't say I've ever taken a bullet in any car I've ever owned.)
Take a look at E-350 or GM 3500 full size vans. Those have decent capacity and can hold all those people in comfort. A custom conversion may have a decent interior, although those are getting harder to find.
Dec-11-2015 02:39 AM
Dec-11-2015 02:13 AM
Dec-10-2015 07:13 PM
sw20td06 wrote:If you want to haul people only a 1500 if you want to haul people and a trailer a 2500. Read the other post about towing with a Suburban. You need to upgrade the hitch as well on the 2500 burb.
What about the Cadillac Escalade ESV? Do they have the same capacity as the 1500 Suburban or are they rated higher?
Also with the Suburban, should I be looking at the 2500 only or will the 1500 suffice?
Dec-10-2015 06:58 PM
Dec-10-2015 06:56 PM
sw20td06 wrote:
I tow with 8 people including 3 little ones. It seems like the only logical choice to haul all those people for a newer vehicle would be a suburban 2500 with the 6.0 , what do you think?
Again I'm looking for a comfortable ride as a daily driver and as a tow vehicle.
Dec-10-2015 06:10 PM
Dec-10-2015 06:06 PM
GaryWT wrote:
Your tongue weight will be about 910 plus the weight of the hitch, you will most likely be more than 150 over. Ford 150 eco boosts generally have higher payloads and they ride better than a 250.
Dec-10-2015 05:35 PM
