Need hardware installed on truck
amy7319
I need the necessary hardware (installed?) on a '99 F350 Superduty. One RV dealer said it would cost $700 for parts and $300 for labor. That seems a bit excessive. The camper is a Lance 835.
What different types of securing is there. I don't know what to ask for.
Thanks, Amy
21 REPLIES 21
K_Mac
Hands down Torklift's the way to go.My neighbor and I put my superhitch and fronts on in under two hours,(his compressor's bigger than mine).Simple instruction's too follow,step by step.They also have a superb staff on hand to answer all your questions. I think my FASTGUNS were the best decision I've made since joining the T.C. world.Well worth the money.RAD Auto beat all other vendors out there.
bikerdib
Shame you don't have a Dodge because I intend to sell my HappyJack tie down system. I bought a one ton and don't need the HappyJack tie downs.
2014 Lance 865 with AC, door awning, all weather package, range w/oven.
2013 Cummins Ram Laramie Longhorn 3500 Crew Cab 4X4 with SuperSprings, Roadmaster anti sway bar, Timbren bump stops & Curt hitch extension for the motorcycle & PWC trailers.
2Gordons
We had Happijacs previously... I did not like them. The camper moved around a lot, and it never felt secure. We went with the Torklifts and have been extremely pleased.
2003 Ford F-350 LB DRW 6.0 PSD, Ride-Rites
TorkLift SuperHitch with 3' Ext., FastGuns and Stable Loads,
Lance 880, Bison 3H Slant LQ GN, 1953 Chris-Craft 18' Sportsman
NEOK
Another fan of Torklift. A friend of mine and installed the tie downs and SuperHitch on my truck in about 3-4 hours. We weren't pushing very hard to get it done quickly either.
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
wintersun
If you are getting Torklift tie-downs for front and back the dealer's price for parts and labor is right in line. It depends on what components will be used, in particular the turnbuckles.
Front and rear Torklift tie-downs $497
Fastguns - two pairs - $440
Lance 7-connector harness $48
Battery isolator or dual battery switch $28
Fuse - $4
8 ga battery wiring and connectors for harness - $15
The unknown is the time to install the Torklift tie-downs on your truck. With some trucks it is easy and could be accomplished by an experienced installer in a couple hours or less. With my 2011 GM shortbed truck it took me 8 hours which included having to saw off sections of plate, grind down corners, and repaint the brackets to get them to fit properly as the sizing for the front pair caused them to hit the frame before the bolts could reach the holes in the bed and one of the rear bracket had its corner pressing against both the rear brake and the fuel lines. Torklift makes a very good product but the 2011 GM kit was not something I would recommend to anyone I liked.
I would guess that there is about 4 hours of total labor so the $300 is reasonable. Best part is it is locked in regardless of the proplems the installer may run into with your truck.
Bottomline the dealer's estimate is fair if you are getting these items and you can get a detailed breakout of the tie-downs, turnbuckles, and other parts to be provided and check pricing out for yourself.
The dealer is not paying "retail" for the tie-downs and turnbuckles so you may be able to negotiate on the installation. I did this with the 845 where I got the dealer to sell me the AC unit at his cost and install it for free. Paid less than $400 for a new 9.3 Coleman unit installed on the camper. Dealer sold the camper and was not out of pocket for the AC so it was a win win result.
Blind_Bob
Just as most everyone else has said, Torklifts.If I remember correctly, 100.00 and about an hour to install. Quality product.
2010 F250 extended cab long bed.
1972 Amerigo
6pac
When we traded our truck in 2001 for a new one . We just ordered a setup from Happijacks an installed it within a couple of hours . It was hot work ,summer in Fl , but it went fast and we saved a lot of $$ doing it our selves . That's what I would do if we had to do it again.
Chevy 2006 2500HD 4 x 4 Duramax / Allison srw cc sb Fh air bags
Lance 2005 model 881 Max
Doriece & Ernest ( 6pac )
Tarkin75
Bought my Torklift's used off Craigslist... Got the directions from the TL website. I'm not sure it even took me 1 hour to get all 4 installed. Maybe an hour, but definitely not two.
Later
C
Bedlam
Moderator
Moderator
Another vote for the TorkLift frame tie downs. I feel if you get one of the heavier campers, there is no other choice. So why not do it right once and not worry about it until you replace the vehicle? The no drill application and Ford's endorsement of using frame based tie downs also won me over...
dakonthemountai
I installed Torklift tie downs on my dually myself also. It's not all that hard, especially if you have a hitch receiver, as they have "side holes" to slide and clamp the rear tie downs to. The front were a bit more difficult, but not too hard. They are expensive, but you only have to do it once! I've never been a fan of the HappiJac system because I hate the thought of drilling into the bed of my truck. But that's just me. I'm not saying they are bad, just not my thing.
Whatever you do, ensure you do it right. Coming on here is the right thing to do, though you will get different opinions. The two systems are really the only way to go nowadays.
Best of luck and welcome to the site! ๐Ÿ™‚
Dak
2018 GMC Denali "Extreme" and 23' EVO 2050T Travel Trailer
Escapee member #224325-Since 1992
SugarHillCTD
I have installed both HappiJac and TorkLift tie downs.
I had liked the HappiJac system because there are no arms to remove and don't rust like the TorkLift "receivers" do. (northern N.H. with lots of winter salt)
But after spending MANY hours installing the front HappiJac mounts on our last truck, I wasn't about to do the swearing routine again.
On our current truck I had the TorkLift mounts on in a couple hours.
If you can turn a couple wrenches, TL is the way to go.
John & Cathy
'12 Chevy 2500HD CC 4x4 sb
'16 Cougar 25RKS w/ Andersen rail mount
'13 Eagle Cap 850 (sold). B4 that a few other TCs and a TT
whizbang
Were are the Happijac fans?
I use Torklifts also. I think mine were about $700 complete installed. Not cheap, but the only way to go.
Whizbang
2002 Winnebago Minnie
http://www.raincityhome.com/RAWH/index.htm
My_Blue_Heaven
Still another vote for Torklift. I tried HappiJack previously and was not impressed. I installed the Torklifts myself, not that big of a deal.
2001 F350 Lariat CC 4WD 7.3 PSD dually, chipped, 4" SS exhaust, 350 hp, Rancho 9000's, front receiver, front & rear Roadmasters
2009 Arctic Fox 990S, storm windows, Cummins/Onan, FastGuns, Torklifts
Scott16
Agree, with Torklift tie downs and fastguns. Go to there web site a lot of installation vedio's with step-by-step instruction . Also check their dealer locator for installers. Another install thread vedio, in this web site is Melo Mike's install Torklift Fast Guns to Wolf Creek 850 thread comes to mine. Do a search in upper left corner of this page.
Scott
US Navy Retired IC1(SW)USS Fletcher DD-992
