May-16-2016 05:37 PM
May-19-2016 09:36 AM
May-17-2016 11:14 PM
portscanner wrote:
stable loads, better shocks, then hit the road
May-17-2016 03:29 PM
May-17-2016 02:00 PM
May-16-2016 11:25 PM
Grit dog wrote:
Agree with the last 2 posts except that the Hemi dually will only haul more on paper. Real world, the load capacity between the gasser and diesel will be very similar. Slight advantage to the gasser, hit not 1000lbs.
May-16-2016 09:41 PM
jimh425 wrote:
If you want it level, you'll need air bags, timbrens, super springs, and/or stableloads.
Take a look at this thread ... 2016 RAM DRW with Arctic Fox 1150.
May-16-2016 09:11 PM
May-16-2016 08:08 PM
May-16-2016 07:48 PM
towpro wrote:
on my 2006, I ran energy suspension blocks on the spring perches. Below picture is after 9 years and maybe 60K miles. I think the energy suspension blocks cost $50.0o for 2 pair. Direct bolt on solution. The torklift upper stable loads are like what I am showing below, only they are solid so they might work better.
On my 2006 the most I ever loaded was 3500 lbs, and they would look pretty squished but they did the job for me.
May-16-2016 07:17 PM
May-16-2016 06:06 PM
May-16-2016 05:49 PM
