New 2017 F350 wiring to Lance plug??
AISURFFISH
We picked up our new 2017 F350 yesterday.
I pulled the lance plug from the bed of the old truck..
Now I need to know which wires do what on the new 2017 F350 wire harness so I can tie this plug into them.
Anyone have a cheat sheet or a schematic?
2017 F350 6.2L Crew Cab
Arctic Fox 990 2021 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF FISHING RODS TICA TO BE EXACT
21 REPLIES 21
Reddog1
Another example of hijacking a thread going off topic. If you start a thread, and it goes off topic with multiple post, click the notify button. I will try to get the thread back on topic. If it has gone too far I will close it. It is reasonable to expect a couple of off topic post, but not hijacks as seen here.
This Thread is closed.
Wayne
Moderator
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Freep
I'm starting to learn that there are some grumpy campers. ๐Ÿ™‚
I googled it for you and found this.
I'd give you a cup of coffee and a donut too, if I could. I hope this helps.
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
AISURFFISH
this is going no-where..
No-one is sticking to the subject please close this forum and I will move on to another forum where someone will help with facts not an opinion..
Powerdude
Yep, I understand about running the fridge on DC while going down the road.
My Dometic works on gas, DC and AC, but on gas the stupid thing does not cool right. It works just fine and dandy on DC and AC.
I put in a new Trojan group 31 battery that has plenty of reserve capacity and pre-cool the fridge. One I get going down the road, the fridge on DC only uses a bit of the battery power, and gets recharged by the truck in a couple of hours. The voltage on the battery is usually pretty close to when I started.
Works really well.
2016 F250 CCSB 4x4 6.2L
2001 Lance 820
Kayteg1
I still don't get it, why 20 amp fridge would not operate correctly on 30 amp fuse with 50 amp rated wire?
I think the only weak link here is the spade connectors in 7-plug and that is why I clean them very well each season regardless paying attention to not drop the plug in the mud.
Would I really want high-amp connection, that is what I would use for charging
BradW
Powerdude wrote:
I was told by the guy who installed my Lance plug that all they do is get the truck side plug and plug it into the trailer wiring harness, all except for the 10 ga wire that they run directly from the battery to power the frige.
So, all the other wires just wire into the 7 pin standard towing harness.
Me thinks I have heard that before. They use the factory plug wires for everything except the two 8 gage wires they run directly to the battery. I assume they fuse the hot side at the battery.
We plan on getting an 2018 F350, so I will have to figure it out sooner or later. I want to wire this new truck with adequately sized wire for the frig to operate correctly on 12v going down the road.
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
BradW
Freep wrote:
Using the stock plug with a converter results in the fridge running off battery and draining it while driving.
Yep, that is exactly what mine does because I tied into the 7-way rv plug on the back of our F350.
Wake Up America
Powerdude
2001 Lance 820
Z-Peller
Good grief Alice!!!....jeez people, give the OP a break..he just asked a straight forward simple question! What is the colour code wiring diagram for his 2017 ford trailer/ camper wiring harness so he can wire it up to his camper plug..I drive a GMC so cannot answer question. Does anyone drive a 2017 ford that knows the truck side wiring harness color code ????
Bill..
2017 Bigfoot 10.4 camper...2016 GMC 3500 4x4 Xcab Duramax Dually...
Kayteg1
Freep wrote:
I did rewire my truck to accommodate the higher draw and the custom harness.
Can you post how you did it on 2017 F350?
My fridge takes like 16 amp @12V and 30 amp factory circuit should be adequate, but occasionally I see my camper batteries not fully charged.
Even I suspect my problem of not delivering rated 3o amp is the cord extension, I am considering adding extra cable to the camper.
Already have 100 amp rated cable and breakers, but than the charging concern comes.
When I deplete camper batteries and my dual alternators will cook them with overcharge, I will be even in bigger trouble.
Freep
Kayteg1 wrote:
OK, I see what this is about.
Once I see the guy showing "his wire" close to the camera and "competition wire" farther from the camera, so it makes impression of huge difference, I know we are talking about lot of BS.
Coming to doing the wiring, the Ford 10ga wire is more than capable carrying 30 amp the relay/fuse in F350 supply.
So are you planning to rewire the truck to make new, higher amp circuit for your camper?
Otherwise you are wasting your time for lot of BS
Charging with more than 30 amp can damage your camper batteries BTW
2014 Lance 992
Reddog1
Kayteg1, there are a lot of people that would disagree with your BS statements. To speak in absolutes can make you look very unknowing. On this subject, my experience is different than yours.
Wayne
Toad: 91 Zuke
Kayteg1
Tamnative
Is this what your looking for?
www.etrailer.com/faq-wiring.aspx
2005 Ford F-350 ex-cab Lariat 4x4 srw 6.0 Powerstroke
2008 Bigfoot 10.4
