โOct-17-2023 05:45 AM
โOct-29-2023 09:04 AM
โOct-25-2023 09:34 PM
โOct-25-2023 02:40 PM
Nero C-Bass wrote:
Well, now that the side is repaired, I've been testing the other systems. Inverter is working, fan in it is a little loud, sounds like a playing card in a bycicle spoke.
Also found that the water heater is bad. It is a suburban unit, went to pull the anode plug and it snapped off. Drilled it out, ran a flush wand through it, and it kicked out a bunch of porcelain material, along with a lot of white crud, probably calcification from never being flushed out.
Lucky enough, camper was built with a water heater bypass, so turned all the valves, and put a few gallons in the fresh tank and ran the pump. Found the kitchen sink cold water fitting is cracked, and the faucet leaks at the knob.
Joy of restoring a 20+ year old unit. Gotta love it.
โOct-24-2023 07:21 PM
โOct-23-2023 03:32 PM
โOct-23-2023 03:25 PM
Bedlam wrote:
Grit, it's only running on half it's cylinders. The other four are are for backup.
โOct-23-2023 01:01 PM
โOct-23-2023 05:32 AM
Nero C-Bass wrote:
Alright everyone.
So I was browsing Craigslist last night, and I found a 2002 tundra with a 4 cylinder in it, already has a flat bed on it.
will it hold this camper? I think it'll do fine if I air the tires up just a little more...
OK where is everyone now? Haha
I am a master diesel mechanic, so I already have most major tools, and a screw gun has definitely been a game changer taking this apart. What's been a challenge is getting all the staples out without damaging the good wood and aluminum. A few have pulled through, but I believe I can reuse all the sheets. Patience is key there.
I'll mention it to my old man, he's the one helping me rebuild it. Back in the 70's he helped me grandfather build their house and garage from the ground up, plus he completely built his RV from scratch using the shell of a 2000 E450 mini bus, so his carpentry skills definitely eclipse mine.
I'll be uploading photos as I go, so far this has been a fun project.
โOct-23-2023 04:00 AM
Nero C-Bass wrote:
Making some progress. Got one jack back on so it'll be more stable. Still need to seam seal the edges.
โOct-22-2023 03:34 PM
โOct-21-2023 05:27 PM
Nero C-Bass wrote:
Unless someone has a suggestion on where to get the proper joint staples ๐
โOct-21-2023 08:00 AM
โOct-19-2023 08:36 AM
โOct-19-2023 05:18 AM
