Newbie
30Mallard
Newbie here, so I will start with a hello to all.
Not only am I a newbie to this forum I am also a newbie to the travel trailer world. I was handed the keys to a 2000, 30 ft fleetwood mallard. I have been giving it a little TLC since it had been sitting in one spot for 8 years and utilized only during the winter months and used solely on city water. Recently we took it out and discovered that the fresh waster reserve was empty. Before I left I had a hose in the fill port for a bit of time until it was overflowing. Not sure when it began overflowing as I was doing other things. When I returned from thr trip I once again put a hose in the fill port and almost immediately it was overflowing.
My question is; do I need to have the pump on during the fill or is there a valve that is stuck closed?
Thank you in advance
25 REPLIES 25
Atlee
The water pump was switched on, correct? If it was switched on, you did hear it run, correct?
You could have a problem with the water pump.
Erroll, Mary
2021 Coachmen Freedom Express 20SE
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
Equal-i-zer Hitch
JohnG4706
30Mallard,
Maybe I'm reading you OP wrong. You indicated that the trailer had been on city water for eight years and you found your fresh water tank empty.
You know there are two separate water systems on your trailer? With city water and city water pressure, your trailer is fed water to all faucets and toilet.
If you use your fresh water tank (with not being on city water), you need to turn-on the water pump to pump water from your fresh water tank to all faucets and toilet. Without using the pump, there is no pressure to push the water through the lines from your fresh water tank.
rbpru
Welcome to the forum. Are you sure the fresh water drain valve is closed?
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
Mark_and_Linda
Welcome to the forum, good place to get some good advice. Don't be afraid to ask a question...but if you get it fixed.....be sure to post a follow up.
Mark
profdant139
Congratulations on two pieces of good fortune! First, being handed the keys to a nice trailer. But second, you will now discover the fun of trailering. Arizona and the southwest are great for camping!
There will be little glitches from time to time, like the water. No big deal -- you will handle it all just fine. Be sure to ask lots of questions!
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
beemerphile1
Check for a winterizing valve and hose just prior to the water pump. It may have been sucking air instead of drawing water from the tank.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Lynnmor
Some find that they need something like this:
Filler
The monitor panels are about as reliable as you first girlfriend.
30Mallard
Lynnmor wrote:
Need a better description of your problem. You put a hose in the fresh water fill and ran it till it was full. Then you put the hose back in and it is again full. What am I missing?
I thought I filled it before we left to the camp site. Error on my part for not checking the monitoring system or the sink and toilet. Discovering the tank was empty at the site. When the trip was over and had it back home I reattempted to fill but it was overflowing immediately. This time I checked the monitoring system and it still shows empty. Time was running out and returned it to storage yard.
Lynnmor
30Mallard
newman fulltimer wrote:
have to fill slow those were known for kinked hoses or odd bends in the fill tube also the vent lf ine could be clogged
Vent? I only know of the city water connection and the fill port.
Is the hose easily accessible?
newman_fulltime
