โOct-31-2020 11:56 PM
โNov-08-2020 06:23 PM
โNov-05-2020 06:11 PM
Dewclaw wrote:
I have not posted for quite a long time but finally figured out how to post pictures. They are more than the size intended. Anyway, now it's easy to see what I'm posting about.
Here is a picture of the skylight showing the place where the piece (lug) broke off.
Here is a picture of the piece that broke off.
Here is a picture of the other skylight latch, still unbroken.
โNov-05-2020 06:09 PM
d3500ram wrote:
I agree with Beagle on the opinion of quality of Heki... I wrote a critical opinion of them in THIS TOPIC.
I had one of the black colored "forks" of the rotating portion break off on my last camper... Crazy Glue did not work. But the rotating part in my situation and the "lug" as you call it are only part of a lock of sorts. I say lock because I am not sure if it is meant to keep the skylight in place while traveling down the road.
You mention that you "rope" yours down, but I just left my as is because there was a significant amount of downward force from the pistons holding it down. I installed new piston because the original ones would not hold the skylight in the UP position. I never worried about trying to get a permanent fix because they really held the window very well in the down position.
But, if you want to fix yours, the frame is relatively easy to take down for a possible fix. Maybe you can install a metal angle with small nuts and bolts to replicate the piece that broke. I had to disassemble mine because the shade slipped out of its guide track slot.
If you choose to take the frame down and the shade works properly for you, DO NOT LET THE SHADE SPRING AND ROLLER COME OUT OF ITS POSITION. It is similar to spring loaded roller shades on a house window in that you need to pre-load the spring. It can be done on the Heli but it is a PIA,
โNov-05-2020 06:04 PM
Z-Peller wrote:
JB Weld makes PlasticWeld. I would attach the broken lug back in place with JB Weld and fill in the topside of the lug with JB Weld at a 45deg angle upwards to give it some strength for pull of the latch. Picture looks like the latch has an ear that goes over the topside of of the lug as well as below, so that may have to be cut off to make clearance for the JB Weld 45deg build out bracing.
For more strength against the upward pull of the latch and because of the upper ear, might be better to use a 90deg metal angle on topside of lug and JB Weld it in place.....
โNov-02-2020 06:25 AM
โNov-01-2020 11:51 PM
โNov-01-2020 10:19 PM
โNov-01-2020 10:02 PM
โNov-01-2020 04:42 PM
โNov-01-2020 02:30 PM
โNov-01-2020 02:14 AM
