โJul-24-2016 04:20 PM
โJul-25-2016 03:43 PM
campkodiak23 wrote:
THANK YOU ALL SO very much for all the information !!!!!!
HAPPY Camping to ALL OF YOU .. you have given me great info ....
โJul-25-2016 03:01 PM
โJul-25-2016 12:00 PM
โJul-25-2016 11:20 AM
campkodiak23 wrote:
WoW... comments / suggestions so far have been great. KD4UPL- I was thinking the actual weight of truck, they are now made from Aluminun and they say they are "light". Fla-gypsy what do you mean properly equipped / poorly configured?
โJul-25-2016 10:38 AM
PUCampin wrote:
Before signing on the dotted line, make sure you check the yellow TREAD act Tire and loading sticker in the drivers door jam. This is the no BS number that states the maximum capacity of ALL occupants and cargo for that specific vehicle as it came off the assembly line with a full tank of gas. It is required by law to be within a few pounds if the actual vehicle was put on a scale.
My Expy EL is 1672lbs as it rolled off the assembly line. This number can vary dramatically depending on cab configuration and options. F150s can have anything from under 1000lbs to around 3000lbs (max payload option), most common is 1400-1800lbs. You want this number as high as possible because every body including the driver and every item of stuff is subtracted from this number before dropping a trailer on the hitch.
Also do not forget, every max towing number is based on a 10percent longue weight. So that 10,000 lb towing capacity means a boat with a 1,000lb tongue weight, NOT a 10,000lb TT with a 1500lb tongue weight which will exceed the hitch rating and probably payload rating and maybe rear axle rating.
As far as weight, even with the aluminum, these trucks are plenty heavy! Good luck with your search!!
โJul-25-2016 10:00 AM
โJul-25-2016 09:54 AM
campkodiak23 wrote:
OK.. Hoping you can help... We are currently towing a T1950 Sunline with a chevy avalanche. In the market for new Tow Vehicle... We are almost ready to close the deal on a F150.
Now we are getting concerned that the new F150's are too light... can you please help
Have been told by dealers that the V6 is plenty. it can pull 10K pounds, but now researching and seems like the 2016's may be "too light". ANY and all suggestions would be greatly appreciated ! We are thinking the V8 would be better ??
โJul-25-2016 08:33 AM
campkodiak23 wrote:Don't fret over it. The new F150s are certainly not to light for your Sunline T1950. We are town a lot heavier TT with our 2016 F150 3.5 EcoBoost and are happy with our combination. ๐
โJul-25-2016 07:46 AM
โJul-25-2016 07:28 AM
โJul-25-2016 03:25 AM
โJul-24-2016 11:02 PM
โJul-24-2016 11:00 PM
โJul-24-2016 08:26 PM
tomman58 wrote:FishOnOne wrote:
I see more new f150 pulling campers than the other brands.
I guess that depends where you are looking.
Myself traveling around the USA and spending months in rv parks don't think so.
Most everyone that really travels uses a 250 or 3/4 ton pick up as a minimum. Those of us that tow 30+ footers normally use a diesel.
I can say one thing about towing, weather, mountains, winds and other driver ...... you cannot have enough truck.
I likr to sit back in my 15" 2500 loaded Dmax and just enjoy the ride lmowing that I've got the truck that will work better, pull better, and ride better then most on the market and I really enjoy the ride.
