Off Road Mashup: ZR2 vs Raptor vs Power Wagon
FishOnOne
For you off road guys...
Enjoy
Link
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
31 REPLIES 31
coolbreeze01
FishOnOne wrote:
DaveF-250SD wrote:
The Power wagon would have made it up the hill if he had gone to the left side of the trail where it bogged down. Like the other two trucks did afterward. they avoided the part where the Dodge was slipping and had no issues. Better tires on the Dodge would help as well. Would like to see a repeat of the test with all three having the same brand and tread pattern tires.
Not sure I agree with this... The Power Wagon's Goodyear tires are probably the most aggressive of the bunch and the PW did try to go around but it's weight worked against it.
And the PW would do even worse with a diesel engine like some want.
2014 Sandsport 26FBSL
rjstractor
Perrysburg Dodgeboy wrote:
I also don't understand why they didn't use the Ram Rebel instead of the Power Wagon.
I agree, the Rebel would have probably done better on that hill. But like I said before, I like the apples-to-oranges comparisons because it highlights the strengths and weaknesses of different classes of vehicles. I don't see it as a Ford vs. Chevy vs. Ram thing like many do.
2017 VW Golf Alltrack
2000 Ford F250 7.3
FishOnOne
DaveF-250SD
2004 F-250 XL Super Cab short bed 4x4 V-10/4R100
1977 Chevrolet Scottsdale C-20 Trailering Special 454/TH400
FishOnOne
bguy wrote:
http://www.motortrend.com/cars/ram/2500/2017/chevrolet-colorado-zr2-vs-ford-f-150-raptor-vs-ram-2500...
Awesome video... Thanks for sharing
Lessmore
bguy wrote:
Civics are good in snow.
On topic, here's a different perspective.
http://www.motortrend.com/cars/ram/2500/2017/chevrolet-colorado-zr2-vs-ford-f-150-raptor-vs-ram-2500-power-wagon/
Civics are no better and no worse than any other small front wheel drive car. They don't have a lot of ground clearance like most other sedans, although they do have one advantage...they're relatively light weight, which is a big advantage when it comes to pushing them out of being stuck in a snow drift.
If a Civic has good winter...or good all weather tires on that will make the difference in their ability to get around in heavy winter conditions. It's about the effectiveness of the tires in snow.
IdaD
A Rubicon Wrangler or similar aftermarket built Jeep would run circles around all of them. Pickups have some inherent disadvantages offroad.
2015 Cummins Ram 4wd CC/SB
Perrysburg_Dodg
Back in the day I ran Dodge Ram Chargers and took them off roading with some buddies of mine. The only thing that could out do my Ram was a buddies fj40. That thing was a beast in any off road environment. Heck he could forge water over the hood. I had to make up a cover to protect the stupid ballast resistor from getting wet and stopping the truck dead in the water!
The one thing I noticed is Ram is the only one that has a shield protecting the fuel tank. Found that a bit strange.
I also don't understand why they didn't use the Ram Rebel instead of the Power Wagon. No the Rebel does not the same off road components that the Raptor and Power Wagon have. But neither does the GM ZR2. Here is a sisde be side test of the Power Wagon and the Rebel. The Reble did very well. http://www.autoguide.com/auto-news/2017/05/can-a-ram-rebel-keep-up-with-a-power-wagon-in-the-arizona...
Still think it came down to the tries on the Power Wagon myself
Don
2015 Ram 1500 Laramie Crew Cab SWB 4X4 Ecodiesel GDE Tune.
Flashman
bguy
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
bguy
rjstractor
Me Again wrote:
My 78 Honda Civic would back up a snowy hill that it could not go up forward. Just saying.
I had one of those myself when I was a kid. Best 2WD vehicle I've ever driven in the snow, not much good for anything else.
2000 Ford F250 7.3
transamz9
Now throw about 4000# in the back of them and repeat the test.
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
ShinerBock
I wouldn't mind a diesel ZR2, as a secondary vehicle of course. Not big enough or capable enough for my truck needs, but perfect for when I don't need that much truck.
2014 Ram 2500 6.7L CTD
2016 BMW 2.0L diesel (work and back car)
2023 Jeep Wrangler Rubicon 3.0L Ecodiesel
Highland Ridge Silverstar 378RBS
