โJul-19-2016 08:54 PM
โJul-26-2016 06:19 AM
โJul-26-2016 05:32 AM
โJul-26-2016 03:46 AM
Need-A-Vacation wrote:
As for your quiet box, I found a YouTube video where a guy just used sheets of wood (can't recall exactly what he used!!!) and leaned them up against the generator at the top. The sheets were a little longer, guessing 4' or so, and directed the noise into the ground which absorbed a lot of it. I will try to find the video again. My thought was to line the wood with the heat resistant foil probably similar to what you did for your generator box.
โJul-26-2016 03:34 AM
โJul-25-2016 05:55 PM
โJul-25-2016 11:40 AM
โJul-25-2016 11:13 AM
โJul-23-2016 05:13 AM
Tvov wrote:
I noticed the "Brutepower" generator in the link you provided does not seem to list noise level... usually means it is LOUD! Looks like a perfectly good generator, same as all the others of that type (open frame, contractor type).
โJul-20-2016 12:35 PM
โJul-20-2016 09:57 AM
2oldman wrote:
Is this music fest the only time you have use for a generator?
ScottG wrote:
I would check to see if the starting capacitor on the ac is blown.
โJul-20-2016 09:55 AM
โJul-20-2016 08:52 AM
โJul-20-2016 07:25 AM
