Onan 2500 Generator Dead Start Switch
Moomba2002
I was wondering if anyone knew if these generators have a fuse for the start switch. Both the inside switch and the one on the generator won't due a thing. It isn't a battery issue and the leads are hot at the generator. Do these generators have a circuit board and if so where is it located? I have pulled my hair out with this one so I am looking to the experts for some help! Thank you.
2017 Ford F350 Super Duty 4x4
Demco Hijacker Autoslide 18k hitch
2017 Columbus 383FB
ExtremeAire 150 PSI 100% Duty Cyle on board air w/4gal. tank
2003 Arctic Fox 1150 loaded except solor
15 REPLIES 15
Moomba2002
Alright have been extremely busy and finally tried working on this problem again this weekend. I have looked for the solenoid to try to jump it but wondering if you have to remove the generator to see it? I wouldn't even mess with it as I always use my Honda but thinking of selling the camper and want everything working.
2017 Columbus 383FB
rckound
Realize this is kind of simple, and most likely you've already checked, but is your spark plug wire on tight? My AF 811 had an issue with the SP wire vibrating off. Just a thought. Good luck.
1996 Ford F350 XLT LB 7.3 Diesel
2008 Arctic Fox 811S
zcookiemonstar
there are a lot of videos on you tube troubleshooting Onan generators.
ticki2
It might have a low oil shutoff . Have you checked the oil level? Just a thought . When you find the solenoid connect across the two large terminals with an insulated screw driver , it should crank .
'68 Avion C-11
'02 GMC DRW D/A flatbed
Moomba2002
Thanks for the replies the 5 amp fuse is good I haven't been able to check the solenoid yet but hopefully tonight. This one has me scratching my head that's why I am thinking the circuit board now I just need to locate it.
2017 Columbus 383FB
AnEv942
Really need to track down a service manual for your unit/model.
I only found this, its fairly old so dont know how simular or not.
http://leipper.org/manuals/rv/onan-kv-repair-manual-981-0506.pdf
Some of the schematics barely readable...section 7 outlines trouble shooting, what supposed to occur when pushing the button.
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
Sam_Spade
Moomba2002 wrote:
Back to the question do these have a circuit board that could have gone bad?
Yes the ignition is electronic with some safeties but nothing on there should stop it from cranking.....I don't think.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
bighatnohorse
Press and hold the STOP side of the start switch for 15 seconds.
Now try.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
blueglide
Moomba2002 wrote:
Yes battery switch is on battery voltage is 13.2 and voltage is 13.0 or so at the generator. I will try to locate the starter relay and narrow that down. Back to the question do these have a circuit board that could have gone bad?
Yes there is a circuit board somewhere inside them...mine was bad from the factory and I had it replaced last year under warranty.
2017 Ford F450 XLT CC 6.7 4X4 Dually
2017 Arctic Fox 32-5m Fifth Wheel
Bedlam
Moderator
Moderator
The 5A fuse identified in the link included in the previous post is the safety for the control power to the start switch.
jimh406
I think there is a breaker. This would probably be better in the more generic tech forum. But, this seems to be pretty helpful.
http://roadtreking.com/help-generator-runs-dont-power/
Bedlam
Moderator
Moderator
I haven't torn into my Onan, but you may be able to short across the two large solenoid posts to see whether the starter cranks. If it does, check for power at the starter switch or replace the solenoid.
Moomba2002
2017 Columbus 383FB
Sam_Spade
What leads exactly are hot at the generator ?
You need to find the starter relay (solenoid) and see what happens on the small input wire when you push the start button.....much like a car. If that works, then you need to check the voltage on the fat wires.
