Aug-13-2015 10:54 PM
Aug-18-2015 07:24 PM
Aug-18-2015 05:25 PM
Aug-17-2015 05:08 PM
Aug-17-2015 01:21 PM
spoon059 wrote:
I still want to see that 100 mpg carb I've been hearing so much about...
Aug-15-2015 10:02 PM
Aug-15-2015 10:13 AM
FishOnOne wrote:Turtle n Peeps wrote:
Well, you did get one correct!!! Good for you!! And just for your knowledge, the 6.4 also had 10 head bolts / head. :B
Actually Navistar used 10 head bolts/head and the 6.4 PSD has very little head gasket failures so it can be made to work.
Aug-15-2015 10:08 AM
RCMAN46 wrote:Turtle n Peeps wrote:
Name ONE diesel engine that shares half as many parts as the 5.7 Olds diesel does with a gasoline engine and I will believe you!!
The GMC V6 back in the 60's had both a gas and diesel which used many of the same castings. Unlike the Oldsmobile I believe the block and crank were identical.
Aug-15-2015 09:39 AM
ChooChooMan74 wrote:RCMAN46 wrote:A man who admits mistakes. Need more like you.
My bad!
The Oldsmobile 350 Diesel did in fact have 10 head bolts per head.
When I looked up Oldsmobile heads I miscounted the head bolt holes and will blame it on getting to old to accurately see what I am looking at.
Aug-15-2015 08:18 AM
Aug-15-2015 07:24 AM
Aug-15-2015 06:44 AM
Aug-15-2015 06:15 AM
My bad!
Aug-15-2015 04:04 AM
Aug-14-2015 11:48 PM
