Outside Kitchen Door Problem
abc40kids
My brothers 2015 Keystone Laredo outside kitchen door all of a sudden has more gap on one side than the other. It's enoug gap to where it's hardto close now. It's been fine, just happend, any ideas to fix? Thanks
Jeff,Julie,Amber,Brandon,and Casey and Winston ( our 5 year old Golden ) and Bruno the Pug. We now have an English Cream, white Golden Retriever as well.
2015 Keystone Montana Mountaineer 356TBF
2005 Chevy duramax dually
7 REPLIES 7
myrvhasnotv
My 2015 Laredo did the same thing. Get the tools out and adjust the top hinge.
abc40kids
bid_time wrote:
Could be too much pressure on one of the stabilizer torquing the frame. Trying loosening them and see if that helps.
That was the issue and thanks for your answers!
JayGee
X2
Jaygee
2005 Bounder 35E on F53 chassis
bid_time
Nomad II
Nomad II
scbwr
Check the latches. The plate that moves when you turn the latch could be attached with a screw which may have loosened. And/or, the plate could have gotten bent from accidently slamming against the frame.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
x96mnn
My trailer just started doing the same thing. Think it is due to the hinge on the top. If I determine exactly and the fix will post back.
GaryWT
Our previous trailer started to do something like that so I would just push it the other way when closing it and it closed fine. We traded it in before we had to do anything to it. Current trailer has been fine. I would start with the hinge to see if it is OK.
ME '63, DW 64, (DS 89 tents on his own, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR 2014 F350 Crew Cab 6.2L 3.73
