Overloaded or wrong truck?
FlatBroke
Hitch Hiker
"08" 29.5 FKTG LS
73 REPLIES 73
valhalla360
Nomad III
Nomad III
I've seen this photo in a few places but no follow up.
I'm betting if we saw the frame, it might be readily obvious what happened.
Of course as others have suggested, might have been user error:
- At 4900lb dry weight, it wouldn't be hard to exceed the ratings if he has full tanks and a lot of stuff.
- Did the owner weld or drill the frame to attach the tie downs?
- How is the weight distribution? There is a lot of camper hanging off the back of the truck bed. The payload sticker assumes a reasonable distribution of weight. What were the per axle loads?
- Did he hit a tope, big pothole or something else at speed?
It's possible there was a defect but it would be interesting to see some follow up with pics of the frame.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Bionic_Man
Ram doesnโ€™t make a DRW short bed in a crew cab. And the minimum payload in a DRW in 2020 was over 6800 pounds. Iโ€™d like to hear more about what happened leading up to the failure.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Grit_dog
Nomad III
Nomad III
Not a short bed and wth is a tope?
It broke. Either defective or the owner got too western with almost 3 tons in the bed down there in Baja. Just because the name says it, shouldnโ€™t drive like a trophy truckโ€ฆ
But the supposition should be strong in this thread. Already on a rollโ€ฆ.
enblethen
Looks like the frame broke in same place as frame mounted tie down connects. If frame was modified for tie downs, you may have an answer.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
deltabravo
ford truck guy wrote:
it looks like a long bed
Ditto.
I think the only short bed dually RAM makes is a Mega cab, which the above truck isn't.
fj12ryder wrote:
Looks like there's a whole lot of truck camper hanging off the end of the truck. Maybe a short bed truck, and a long bed camper with 3 slides? Baja California, so add in some rough roads.
Sure looks like thereโ€™s a lot of panel in front of the rear wheels for a SB ??
At least the way I see it, it looks like a long bed
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
time2roll
cptqueeg
150 gal total btwn fresh, gray and black, should have been more clear in my language.
2024 Chev 3500 CCLB Diesel
Four Wheel Camper Granby Shell
ksss
I don't think your fitting 150 gallons of fresh water in a slide in camper. If you couldn't haul that camper on a 3500 DRW without it being over weight, what is your option, a 450-4500 only? I have to think either that truck wasn't right from the factory or they ran the Baja 1000 while they were in the area.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
Geo_Boy
cptqueeg wrote:
EC 1165 dry weight 4917lbs
Lots and lots of heavy options, big water tanks (-150 gal fresh, grey, black), etc, etc.
Definitely OVERLOADED!!
cptqueeg
Lots and lots of heavy options, big water tanks (-150 gal fresh, grey, black -total btwn all 3), etc, etc.
fj12ryder
Howard and Peggy
"Don't Panic"
midnightsadie
seen this on old trucks but not as new as yours get dodge on this and write everything down and plenty of pics. good luck .
mooky_stinks
Impossible to tell unless I was in truck during failure. Truck should be capable.
2020 F150 XL Screw 4x4 6.5โ€box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
