Feb-16-2019 01:59 PM
Feb-17-2019 05:21 PM
Feb-17-2019 04:42 PM
FishOnOne wrote:11-14 is about when I remember Ford wimping out the 450. I knew quite a few people in the Dog trial world that had them when they first came out.Huntindog wrote:
I remember for some years the 450 pickup had smaller axles, and IIRC, the wide track front axle was an option, then I believe they made different GVWRs available. Some actually had LRE tires. Not sure if that is still the case.
The wide track front axle was always standard for the F450 and was an option for the F350.
The F450 ran 17" tires from '11-'14. All other years they ran the 19.5" tires.
The F450 has a larger rear axle, larger brakes, heavier front suspension components, and a different rear spring pack than a F350.
The F450 is simply a beast...
Feb-17-2019 04:14 PM
spoon059 wrote:4wheelingNUT!! wrote:
Ok, looked at F-450 Platinum 4wd, with all the bells, and whistles, has the fifthwheel prep pkg. The stamped limit was 4770 lbs for cargo payload carrying capacity.
The F450 comes standard with DRW, correct? I'm amazed at such a low payload. I've been DRW 1 ton diesels with almost 6,000 lbs of payload...
Cummins12V98 wrote:
"The F450 is simply a beast..." One could say so with a straight face, BUT it can't tow my measly 23K RV without being "overloaded".
Feb-17-2019 04:10 PM
Do they have the same front axle?
Feb-17-2019 03:38 PM
Overloaded per what specification? You know as well as I know, their is manufactures warrant/weight spec, paid for license spec. Sum of axle only vs gvwr which is usually less than sum of axles in most class 1-4 or 5 rigs.
Which smoke and mirror spec do you want us to use?
Marty
Feb-17-2019 12:11 PM
Feb-17-2019 11:06 AM
Feb-17-2019 11:01 AM
Feb-17-2019 10:43 AM
Feb-17-2019 10:31 AM
Feb-17-2019 09:53 AM
Feb-17-2019 09:49 AM
agesilaus wrote:
No the hitch is not included in that number nor is the weights of the passengers, misc cargo or anything else. You may need a MDT
Feb-17-2019 09:43 AM
