Hi, looking for some tip on how you manage your potable water. When boondocking for longer period, potable water become sometimes a problem.
Myself, I buy water for daily drinking, I carry a 5 gallons spare and I have enough for many days. Normally I would use my camper reservoir water for coffee and cooking. But sometimes you fill up with water that have a bleach smell or not so fresh smell and not sure if it is still drinkable.
Do you use a filter, and if so, which type would be the best to fill up?
Do you add bleach or other sanitizer to your water? If so, how much?
I found a way to reduce my use of potable water. I use an external reservoir, I get as clean water as possible from a river or a lake and add some bleach. Selecting the winterizing valve, instead of using the water from the camper reservoir, I pump water from the reservoir for shower, this way I can have as many shower I want.
What are your tips?
Monaco Cayman 34 2003, Cummins 300HP
Bigfoot 2008, 10.4, F350, 2006, Diesel 6.0, Black, 4x4, long box, Air lift, Rancho 9000, Rear sway bar.
