โJun-30-2016 09:56 PM
โJul-10-2016 06:01 PM
โJul-07-2016 09:41 PM
โJul-07-2016 09:36 PM
โJul-07-2016 08:18 PM
โJul-06-2016 10:05 PM
โJul-02-2016 06:38 PM
โJul-02-2016 06:20 PM
โJul-02-2016 09:29 AM
โJul-02-2016 07:40 AM
Alpinliteford07 wrote:Yes something like this:
when you say connect to a existing circuit via transfer switch, are you talking 120v?
โJul-02-2016 06:44 AM
kohldad wrote:
Since you have the upfitter switches, just use the 30A switch set to controlled by ignition. It is actually a relay controlled by the switch and will handle the amps you need. No need to add an isolator too.
โJul-02-2016 06:42 AM
โJul-02-2016 06:17 AM
โJul-02-2016 06:07 AM
logcruiser wrote:
I am also researching this and I would put a battery isolator that would be wired to truck ignition on 12V. That way it disconnects the camper from the truck batteries when the ignition is off. Can anyone recommend a good 2000W pure sine wave inverter?
โJul-02-2016 05:00 AM
