May-22-2013 02:20 PM
Jul-17-2013 06:58 AM
Jul-10-2013 04:12 AM
Capt RonB wrote:
Still a 10hp gas engine vs a 10 hp propane engine produces the same 'lectric output. The difference will be the cost of fuel which as near as I can tell is about break even.
Also while we're on the subject, why does a 'Sportsman' 4000 watt genset cost $900 and a Honda or Yamaha Equivalent cost $4000? I know I want a quality generator but the price difference seems extreme.
Jul-10-2013 12:22 AM
Swampman597 wrote:
...I see the Beem 2700 watt unit claims it consumes .38 gph which sounds pretty good.
Jul-08-2013 08:13 PM
May-23-2013 03:43 PM
May-23-2013 02:13 AM
DesertTracker wrote:
I had a propane Generac on a Lance camper I owned before my current trailer and found it to be very convenient. It did not seem to use a large amount of propane and best of all, since I live in SoCal, it could go from sea level to 9000 feet in altitude without having to do anything but push the start button. It was a XXXX"P" generator and designed from the factory for propane; maybe the conversion kits cause less efficiency? (just speculating). During winter shutdown and storage, I did not do anything like on the gasoline generator with draining the carb bowl and gas tank of gasoline. It seemed pretty forgiving when I would forget to run it monthly also; after a long period of sitting, it would fire up and power my A/C and anything else needed pretty much immediately. Just my experience.
May-22-2013 07:56 PM
May-22-2013 07:03 PM
May-22-2013 06:49 PM
May-22-2013 06:14 PM
May-22-2013 06:13 PM
May-22-2013 06:11 PM
May-22-2013 04:22 PM
May-22-2013 02:43 PM
