propane heater in trailer while traveling
NYCFive1
Advice on heating the travel trailer while traveling ? This is the first time we are traveling with a trailer from NY to FL in cold weather. It will be cold when we stop to eat and we can't take the dog into a restaurant. We are planning to leave Cleo in the trailer while in the restaurant. We want to preheat the trailer for 2-3 hours while traveling. The only posts I have found are for MH propane heaters while traveling.
NYCFive1
27 REPLIES 27
Jack_Diane_Free
Dog has a fur coat on already. It will be ok.
NYCFive1
Definitely will turn off when fueling. This is my 7th RV since 1980 . The spoiled 13 year old Lab mix rescue dog doesn't like to get cold especially after her walk. Cleo chose the CG we are staying at because it has a dog run. The training is going well. Cleo is pleased with our progress.
NYCFive1
2 days ago I traveled from Calgary Alberta to near Vancouver BC.
Roads were dicey in many areas, especially over mountain passes.
I didn't want my water etc. to freeze up so I ran with the furnace on the whole time.
It kept my TT toasty warm inside, so on my many stops, it was quite comfy.
Had to drive carefully and slow in many places. I was 14 hours on the road with the furnace on the whole time.
No problem.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
n7bsn
old guy wrote:
just turn it off when refueling please.
What they said, spark+gas fumes== bad things
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
midnightsadie
seems to me all the heat would be sucked out of the TT as your going down the road. rv,s are not well insulated.
NYCFive1
OOPS SAR Tracker (Darn spell correct)
NYCFive1
old_guy
K_Charles
We have left it on while traveling but doesn't save you much. If you stop turn on the heater, and then take the dog for a walk, the trailer will be warm enough for the dog. By the time you cook or buy your lunch the tt will be worm enough for you too.
Andymon
Why not just keep the dog in the truck?
2008 Springdale 266RLS
1999 F250 7.3
Medford, Oregon
NYCFive1
Thanks for the replies.
SAT Tracker--Yes factory installed propane heater.
NYCFive1
SAR_Tracker
Just to be clear here.... We're talking about using the factory installed furnace in the TT, and not a stand-alone heater attached to a propane tank running in an enclosed area, right?
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
DutchmenSport
I must have missed this discussion in the past. I've often wondered, but never had a need to travel with the heater on. Thanks!
ScottG
Been discussed here many times - perfectly OK to do!
The only time I wouldn't do it is if a slide is covering a register but I've never seen that situation.
