jeraco's avatar
jeraco
Purchasing First RV- would like some advice...
Wife and I are starting to F/T RV life in spring 2020 and are looking to go ahead and get the rig now so we can play around, customize, and learn how to use it and drive it on some short weekend trips. In the backpack community, we call these "shakedown" hikes. :)
This will be our first RV. It will be the two of us humans plus two canines (one large one small). We are avid tent campers so we plan to do a good bit of boondocking/off grid/off-road camping. I'm thinking BLM,National Forest, and state maintained campgrounds. (Perhaps after the first month or so, when I learn better what I'm doing)
Our short search has pulled us toward a late model, pre-owned unit to save $$$, but still have modern conveniences. The model we like best now is a 2018 Flagstaff Micro Lite 25KS for these reasons:
-4800 UVW
-higher quality finishes/build(?)
-large water tanks
-2 entry doors
-walk around queen bed (or murphy option)
- ability to access the unit with the slide closed
-small slide
-solar charge point
-not too large of a rig (??) for first time RV driver, but large enough to be comfortable
- Used units in great condition can be found for less than $20,000
-3+ season comfort (so says the salesman)
That's not all, but you get the idea. I'm not seeing much opinion about the MicroLites- anyone else have any experience with them? What else should I be considering? Any other brands you recommend? BTW, we are in the Southeast USA. Also, we will be using a 2016 Ford F-150 V6 4X4 Lariat as our vehicle (11,500 tow cap).
Thanks and I look forward to hearing from you!
