โMay-20-2015 10:42 AM
โMay-22-2015 09:12 AM
โMay-22-2015 05:15 AM
2012Coleman wrote:
Thanks all - I finally got the bulb out. I took a look at these and see that there are emitters all around. What good does that do against a plastic reflector like mine?
โMay-21-2015 12:47 PM
DocnAK wrote:
Agree with the above. You should just be able to pull on the glass part. Have you tried another fixture to see if they are all that tough to take out? I had the similar light in our TT and replaced with these....
http://www.m4products.com/921-24-5050-ww-warm-white-5050-smd-light-bulb-with-wedge-base/
Very happy with them.
โMay-21-2015 10:54 AM
DocnAK wrote:Thanks all - I finally got the bulb out. I took a look at these and see that there are emitters all around. What good does that do against a plastic reflector like mine?
โMay-21-2015 05:59 AM
โMay-20-2015 06:59 PM
โMay-20-2015 06:32 PM
2012Coleman wrote:pconroy328 wrote:Did you replace with LED?
Oh heck - the fixture says 921.
So wiggle and tug.
Wear gloves or take caution just in case the glass breaks!
I'm also wondering if I can replace the backing with something reflective. Otherwise, I guess my LED lights will be the ones that are flat and one sided.
โMay-20-2015 04:53 PM
โMay-20-2015 11:16 AM
So wiggle and tug.
โMay-20-2015 11:10 AM
So wiggle and tug.
โMay-20-2015 11:02 AM
โMay-20-2015 11:01 AM
โMay-20-2015 10:56 AM
Wishbone51 wrote:Yes - my thoughts as well. Pushed with my finger, then the blunt end of utensil. It would not budge.
It looks like that's some sort of clip at the bottom. Is there some piece of flexible plastic that you can push to release?
