Sterling1
May 03, 2023Explorer III
DWeikert wrote:
A little late to the thread but just throwing this out there. Instead of 2 100ah batteries is there a chance you would have the space for one 200ah battery? For example -
JITA 12V 200Ah Plus LiFePO4 Battery
Wiring is much easier and solves the problem of trying to balance the cells across 2 different batteries.
My $0.02
Dan
The battery would probably fit but I've already got the batteries. I could just put a jump wire across the positive terminals (like I have on the negative terminals) if I wanted to bypass the positions on the switch (there would be no difference between A/B/Both from an operational standpoint) to alleviate any balancing concerns. But I do like the ability to isolate the batteries from each other if I want.
Thanks
44,025 PostsLatest Activity: Feb 26, 2025
