Nov-22-2014 07:19 PM
Nov-26-2014 07:10 PM
Shadow Catcher wrote:
One of my concerns was ground clearance, the other concern is center of gravity. If you raise the entire trailer you mess up the dynamics. Two alternatives a skid plate at the rear of the trailer and air shocks/airbag to temporarily raise the trailer, and incidentally improve the suspension.
I have a Dexter axle I may eventually switch to a Flexride which is adjustable.
http://www.ucfamerica.com/flexiride.html
Nov-23-2014 04:53 PM
Nov-23-2014 05:58 AM
Nov-23-2014 03:11 AM
Nov-22-2014 09:47 PM
Old-Biscuit wrote:
NO!
Axle tube is bowed upward to properly set camber
Here is some info for you........LINK
Nov-22-2014 09:33 PM
Nov-22-2014 08:36 PM
Old-Biscuit wrote:
Yep.......
Called an 'axle flip'
Leaf springs relocated to top of axle vs being on bottom of axle.
Should have new spring perch welded to top of axle tube so leaf pack 'sits' on axle properly (with locating pin) and then NEW U-BOLTS
Nov-22-2014 08:18 PM
Nov-22-2014 07:53 PM
