Feb-15-2023 11:05 AM
Feb-16-2023 07:19 AM
Desert Captain wrote:
The big issue for the OP is what payload does your truck have. As noted earlier Ram 1500's are notorious for limited payload. Crew Cabs and 4 X 4's are heavy options that subtract from the original factory payload numbers.
"The tow vehicle is a 2016 Ram 1500 that has upgraded shocks, springs(TufTruck XHD), sway bars, Helper airbags and E-Rated tires. I will be using a weight distributing hitch just like I do with my current 26Ft Shadow Cruiser and my vehicle does have a brake controller/tow package."
None of the above will change the trucks payload.
Shortly after buying my 2019 Honda Ridgeline a guy I know tried to take me to task... "Why didn't you buy a real truck?" he asked. When I asked for his definition of a "Real Truck" he proudly pointed to his Ram 1500. When asked what his payload was he got kind of sheepish and said he wasn't sure.
I had him open the drivers door and there on the sticker it showed his payload to be 977#. My Honda is 1,477#. Almost made him cry. The OP is going to run out of payload with this trailer before he loads any gear or passengers. The other concern IMHO is that much trailer will be a textbook example of the tail wagging the dog... and not in a good way.
As always... Opinions and YMMV. Good luck.
:C
MFL wrote:
"None of the above will change the trucks payload."
^^This is true, will not change the payload sticker.
The improvements made to OPs truck will improve handling and capability, of his truck, compared to stock setup.
Jerry
Feb-16-2023 06:57 AM
MitchF150 wrote:
That's gonna be a lot of trailer for sure. I've got a 13 F150 EcoBoost with the "maxtow" option giving the truck a #7700 GVWR and #1900 payload.
I can tell you that I'm maxed out with a 26' #7000 GVWR trailer...
I do pack heavy, and it's only 2 of us, so my trailer does not need to be that big , but it's all up to what you feel comfortable with in the end.
Like has been said, you have towed with your truck before and know how it handles your last trailer. I think you'll be a bit surprised at it's actual weights on the new one when it's wet...
We all don't think we pack much.. But, how much do we all add over time?
Anyway, good luck with it and waiting 5 years to buy a new truck is gonna be a lot more $$ than just buying one now..
I'm not even looking at new trucks in my future.. I'll replace the engine, trans, whatever on my 13, as it'll be cheaper than even a used base model truck that's newer than what I got now and I don't plan on getting any larger in TT either.. But, that's just me and no growing family! 🙂
Good luck! Mitch
Feb-16-2023 06:56 AM
Feb-16-2023 06:16 AM
mdsonofthesouth wrote:Lantley wrote:
A 33' long 9600# GVW TT will put an average 1/2 ton at its limits.
On a good day you may be on OK.
On a bad weather day you will be taking your chances.
Stay on the flats you maybe OK, go into the mountains and you are testing your limits.
I live in MD and I can travel North, south or east of Baltimore with ease however if you head west the equation/landscape changes quickly.
I always want my combo to be set up to travel with out limitations.
The combo you are considering will NOT be without limitations!
Yep sadly have lived here all my life. Doubt Ill pass much further west than Frederick to Brunswick area. Most of my driving would be to the Outer Banks, eastern shore, Central MD to NC maybe. I know until I get the 2500 Ill have limitations and will avoid Appalachia for sure! Heck I wouldn't want to go to the mountains without an exhaust brake no matter the size of my camper.bikendan wrote:
You didn't post what the driver's door sticker says is the truck's payload capacity. 2016 Ram 1500s were notorious for poor payload capacities.
Figuring that having 1000lbs of axtra trai,er weight, when loaded for camping, 12% would mean a ballpark tongue weight of 984lbs. That goes against the payload number, then subtract the weights of everyone in the truck, any truck cargo/add-ons weight and 100lbs for the WDH. If there's any payload capacity left,you should be OK.
The 280BH is 7100-7200 dry, add ~1000lbs (probably will be much less) in "stuff" and then 13% tongue weight will be around 1100lbs. The kids, wife, dog, stuff and myself are ~540lbs. If I put the bikes and such on the back of the camper I should be around my payload capacity.
No matter how I slice it Im extremely close to my limits and the more I think about it the more I get uneasy with the proposition. Sad thing is my current RV looks like it will be in its last year before I have to do serious frame repairs or sell it if I can. If I get a camper I'm 5 years from a new truck and if I get a new truck Im 5 years away from getting a camper...unless I win the lottery.
Feb-16-2023 06:13 AM
Feb-15-2023 09:25 PM
Feb-15-2023 07:11 PM
blt2ski wrote:
1000 lbs or less stuff in trailer....
Had a fellow moderator say in his new trailer he would load less than 750 lbs for wife and himself. I laughed, said 1000-1200 lbs. Not going to say who was correct. My family of 6 were typically 1500-3000 lbs in our 24' trailer, depending upon if it was a summer weekend, or a 3-4 day ski weekend. Let's not mention the day we got 20 miles down the hill, and had 6000 lbs of snow between the trailer and what was in the bed of the truck. Pass got shut down for 4-5 days, they lets us leave with an hour or two notice.
My 02 on what you will really pack! 1500-2000 would be more realistic.
Marty
Feb-15-2023 06:58 PM
Feb-15-2023 04:55 PM
Feb-15-2023 04:06 PM
Heres a link to the exact camper: https://www.keystonerv.com/product/springdale/comfort-travel-trailers/floorplans/280BH
So per the specs of this Travel trailer I should be fine with proper loading of my truck, but what worries me is the length of this new TT. The original plan was to get a few more years out of the shadow cruiser until I can get a Ram 2500, but the camper is causing me too many headaches left over from the previous owners + we need more room for the family and dog. No mountains are in our immediate future and most trips are ~3 hours or less.
So do yall think I can safely tow this camper? Thanks!
Feb-15-2023 03:57 PM
Feb-15-2023 03:39 PM
MFL wrote:
At 33', that would be a chore to handle in the wind, if truck was in stock form. With the upgrades you have, suspension, E-rated tires, I'd sure give it a go. You are an experienced tower already, and should recognize if it handles poorly. Make sure to have your hitch wt at 12-13%, if you aren't overloading your receivers capability.
Welcome to the forum, and good luck!
Jerry
Feb-15-2023 01:10 PM
Feb-15-2023 01:01 PM
TurnThePage wrote:
If it's within specs, and considering your upgrades, I would go for it. You may want to consider a high end sway controlling WDH. I'm actually in the same boat right now with my Ram 1500. I've been instructed to purchase a little longer than I had planned so we can accommodate kids and grand kids.
Feb-15-2023 11:54 AM
