Ram 3500 questions? Help me .
hammer21661
I've been racking my brain on what truck to get. I know I'm getting a Ram 3500 Lariamie. I would probably just get the srw if it was available with a 3.73 rear but it has to be a dually to get that. I have a brand new one with 4.11 rears now but the noise at 60 to 70 mph is very annoying to me I'm told the noise is less with the 3.73 gears or should I just get the srw with the 3.42 rear and like a 20 inch wheel bit it doesn't have overload springs either. Also anyone who has a like truck can you tell me your mile per gallon. Still pulling the fuzion in the signature. Thanks in advance.
2018 Ram 3500 SRW crew cab long bed 4x4 diesel Lariamie 1-2018
2013 fuzion 322.8/25/2012
2000 Yellow Lab mix Dog, Earl,The One who gave me Unconditional Love picked up 9-12 or 13, 2001 till 2-7-2014 may he r.i.p.
33 REPLIES 33
Hiking_Hunter
Greene728 wrote:
Truck in my sig has the 3:42.
Fuel mileage is 16.5โ€“18 normal every day driving, and seen 20-22 on interstate just cruising at 70ish.
Towing itโ€™s worst has been 10.2 and best of 11.8. All mpg numbers are fully stock.
Lock out 6th gear, engage EB and TH and itโ€™s a pulling beast.
Same here - 2013 model SRW, same rear end. Dragging 11,800 lbs. I get 11.5 to 12.2 mpg. I also lock out 6th unless I'm in the flatlands. Love the exhaust brake. No regrets for me on the SRW, however, if you think there's a chance you will ever be pulling a camper that requires the extra pin weight capacity then go with the dually.
Amateur Radio WA4GIY
2015 Montana High Country 305RL
2013 RAM 3500 4x4, crew cab, long bed, 6.7 CTD, Aisin trans.
CGVW 20460 Lbs.
996Pilot
I have the 3500 Laramie Longhorn SRW 6.7 Cummins and same as Greene728 about 16-18 city and 21 hwy at 70mph. Camper and small trailer with a Harley on it we averaged about 16mpg to/from Colorado at about 70MPH the whole way.
2018 Arctic Fox 811
2015 RAM 3500 SRW Laramie Longhorn 6.7 Cummins 68RFE Timbren SES, Lower Stableloads
2006 Dodge Ram 2500 Laramie 5.9 Cummins 48RE TRADED
2006 Outfitter Apex 8 TRADED
Greene728
2011 Crossroads Cruiser 29BHS ( Traded )
2017 Grand Design 303RLS ( Sold )
Currently camperless ( Just taking a break )
2016 Chevy Silverado 2500 4x4 6.0 and 4:10โ€™s
Me and the wife and our two daughters. Life's good!
donn0128
I have the same truck right down to the 4.10 rear end. No complaints with noise from me. Super quiet as far as Im concerned. You might consider spending a few dollars and having some dynomat installed.
