Mar-25-2017 08:43 PM
Mar-29-2017 03:16 PM
camp-n-family wrote:Dealers ALWAYS have the tire pressure screwed up on vehicles on their lots. With the 3500 I do not know why the OP did not just let some air out of the tires himself. I would have in his situation, I would have walked over to my truck and gotten my air gauge and set the pressure to what I want for the test drive.
I would've but I was pressed for time that day and didn't have a gauge with me. Either way I was happier with the ride in the 2500 and signed the deal today. Thanks all for the input.
Mar-29-2017 02:54 PM
Mar-29-2017 07:34 AM
IdaD wrote:
Your truck is rated to carry a whopping 500 lbs more on the rear axle than the truck OP bought. Yay.
You ought to buy a DRW or better yet a MDT/HDT if you want to tie your masculinity into what you drive.
Mar-29-2017 07:15 AM
Me Again wrote:IdaD wrote:
Honda is making the Ridgeline again. Maybe you should test drive it?
What value are you even trying to add with this post?
It was an attempt to point out that if one wants a truck to do real work there is a trade off!
I love may 2015 SRW 3500 CC 4x4 SB. It rides a little ruff under some conditions. I resolved quite a bit of that with Rancho 9000 rear stocks on my 2001.5 and have always lower rear tire pressure when I wanted a better ride empty.
I wanted a truck that could tow a large 5th wheel and cruise better on the freeway bob tail. I got it in the 2015 3500. This is a short section of Hwy 60 between Mesa and Apache Junction that causes a slight stutter for a mile or so. I can live with that for the capability the truck provides.
Friday I am moving a friends trailer to storage and have to air the rears up, and will let them back down after I also move our trailer to a different lot in the park to have it next to our new park model for two to four weeks before we head back North.
Chris
Mar-29-2017 07:05 AM
Mar-29-2017 06:08 AM
Anybody using a Ram 3500 diesel that can shed some light on driving it as a daily driver? I have a 2500 hemi now that drives comfortably enough. As far as I know the only difference is the extra overload springs. They won't engage unless loaded so I'm assuming the unloaded ride should be similar as my current truck?
The dealers have been calling with trade offers which I usually ignore but the latest is an offer I'd be stupid to refuse. I was planning on another Ram 2500 as I don't need a 1 ton truck but when I price out the same truck in a 3500 series it is only $400 more. Seems crazy. What am I missing?
Mar-29-2017 06:03 AM
Me Again wrote:camp-n-family wrote:
Now that we have separated the men from the boys based on what make they drive, maybe we can get back on topic.
I managed to get out today to find the answer to my own question. I was able to drive 3 trucks back to back. My own '14 Ram 2500 Hemi with winter tires aired to 36psi, a '17 Ram 2500 6.7l @78psi, and a '17 3500 6.7l @76psi. The dealer wasn't able to drop the pressures for my test drives. (service bays were busy)
As I had figured, the ride was considerably different. After several concussions and some back problems I may be a bit more sensitive than others, hence the concern. I drove my truck to the dealer, then the 3500, followed by the other 2500. The exact same route for each.
The two 2500s had no real noticeable change in ride, even with the different tire pressures. If anything, the new diesel 2500 was slightly smoother Manhole covers, railway tracks and large bumps felt the similar in each truck, only slightly harsher as expected in the 3500.
The rest of the drive the 3500 was a different beast all together.
You could feel every little ripple in what appeared to be smooth roads. The truck would shudder and shake without even a crack visible in the road. The empty front seat rattled the whole way and the seatbelts would bang against the doors. By the end of the 15 minute test drive I had developed a mild headache and my back muscles had tensed up.
I expected a truck ride and am used to one, but I didn't expect to feel beat up. Maybe I'm just getting old. After driving the 2500 next my mind was made. Even for nearly identical prices I will be signing for the softer 2500.
Thanks for (most) everyone's input.
Mar-29-2017 05:22 AM
I have not as I have seen and heard of too many problems with the system, especially in cold climates. It is an expensive option that helps with towing ride but from what I have read, doesn't do much for the unloaded ride. Doesn't seem worth it.
Mar-29-2017 05:16 AM
spoon059 wrote:
camp-n-family, maybe I missed it, but have you test driven either the 2500 or 3500 with factory air? It seems that either of those trucks would ride considerably better with an adjustable suspension that is aired down if you aren't hauling weight.
Mar-29-2017 04:54 AM
Mar-29-2017 03:42 AM
Mar-28-2017 09:17 PM
Whatchaupto wrote:
camp-n-family: why would you want to buy another Ram after your apparent dissatisfaction with your current Ram after four transmission rebuilds or replacements?
Mar-28-2017 08:14 PM
Mar-28-2017 08:07 PM
