Rear suspension help
ib516
1. No I'm not overloaded. 🙂
2. Now that we got that out of the way....I have the 2007 Dodge Ram 1500.
I tow a 17' hybrid TT. The TT has very limited storage and cargo carrying capacity. So, we load up the bed of the truck with camping junk like lawn chairs, generator, spare tires (2), bikes, and I also add a ladder rack and carry a kayak on top. There's just 2 adults in the truck. I also don't use a WD hitch since the TT only has a 350# tongue weight.
So the back end of the truck squats a little more than I'd like. My headlights aim high too because of this.
So I'm shopping for some help for the rear squat.
Here's a couple pics.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
22 REPLIES 22
ib516
I have weighed it, I'm not over loaded on payload or rear axle GAWR. The truck has fairly high miles and the rear springs are a bit tired I'm thinking. The shocks are new as the old ones were completely blown out.
fj12ryder
Check your weight, I'm willing to bet that you're very close to being overloaded. With that much stuff in the truck it would be good to know if you're in danger of exceeding the weight limit of your tires.
Howard and Peggy
"Don't Panic"
Boomerweps
They do make light duty WDH.
And you can find several for about $200 shipped on eBay.
Cheap as or cheaper than most alternatives and it will make your towing smoother.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
donn0128
Add an equalizer hitch. That will transfer some weight foreword to the front end. Drive across a set of scales next time your loaded for a trip and get accurate weights. That alone will give you a true picture whether your loaded to the max, overloaded or what else. Then you can decide on a proper course of action.
cummins2014
ib516 wrote:
Suggestions of equipment that you've used that has worked well?
Its hard to argue a set of airbags, it will sure solve your issue. I would put them on ,and be done with it. Most go airbags for your type of issue
ib516
ib516
This is loaded and hitched up.
2.5 inches between bump stop and axle.
Click For Full-Size Image.
ib516
This is without a load. About 4.5 to 5 inches between bump stop and axle.
