Regular or premium
d1h
Nomad III
Nomad III
I know that Chevy recommends premium gas in the 6.2L engine. What do all of you out there use? Is using regular a bad idea?
28 REPLIES 28
Retired_JSO
My 2019 corvette 6.2 has premium fuel recommended. My 2019 Yukon also is recommended premium. I use regular in both and have in every car or gasoline powered truck Iโ€™ve ever owned since 1963. No ping
philh
if the mfg recommends premium, why would you consider anything else?
azdryheat
I go with what the book says. My car is regular gas, Harley was premium, RZR is regular, truck is diesel.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Sjm9911
I will say in the 2020 book it says 6.2 is premium. I have the 6.6 , and thats reguler. Its only the 6.2. Like above i had many gm trucks all were reguler. I atually called the dealership to make sure the 6.6 was regular. As the manual is a bit confusing for the 2500s.
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
ShinerBock
MitchF150 wrote:
I've actually started running premium in my 13 Eco for the last 2 years now and towing my #7000 TT now compared to the old #5000 TT it makes a world of difference..
I just keep it going when not towing too.. Truck seems to really like it, especially with 93,000 miles on it now.
It's getting the best mpg's it's ever gotten not towing. Same route, driving the same way..
I towed my new #7000 TT the first time with 87 in the tank... It was a dog. Thanks to the knock sensor, it ******* the timing so much, it had no power to haul the new beast the way I was used to with the old trailer..
Remember, you just can't dump a half a tank of premium in and expect night and day results. I ran at least a full tank of premium before I towed the new trailer the second time on 92. It was a night and day difference for sure. Well for me anyway.. Your mileage may vary.
My owners manual for the Eco says it'll run fine on 87. But, if you tow heavy, they recommend running 92.
So, no idea on your 6.2.. But, I would say that if the manual recommends running "premium"... I'd go with it.. ๐Ÿ™‚
Good luck! Mitch
The 3.5L is a variable fuel engine in that unlike most fixed cam/timing it can adjust timing, valve overlap, and so on to take advantage of different octane ratings. I believe it was Pickuptrucks.com who published that Ford stated that the 3.5L Ecoboost 365hp/420lb-ft on regular fuel went up to 385hp/430lb-ft on premium fuel. So unlike most engines, you are actually seeing/feeling a power increase.
2014 Ram 2500 6.7L CTD
2016 BMW 2.0L diesel (work and back car)
2023 Jeep Wrangler Rubicon 3.0L Ecodiesel
Highland Ridge Silverstar 378RBS
MitchF150
Good luck! Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
RetiredRealtorR
What a wonderful surprise for new truck buyers!! So, it's a given that Premium fuel runs about 40% more than Regular. That being the case, if a person drives only 15,000 miles per year, and is fortunate enough to achieve an average of 15 miles per gallon, his annual outlay is probably going to be about $800 more than a truck that burns Regular fuel.
To me, that's a lot of money for, really, nothing. But on the other hand, if a person is dropping 80 or 90 grand on a truck, I imagine an extra $800 per year is fairly insignificant.
. . . never confuse education with intelligence, nor motion with progress
Old-Biscuit
ShinerBock wrote:
The problem with comparing the GM Ecotec 6.2L with all those other engines is that the 6.2L has a compression ratio of 11.5:1 while all the others stated are 11.0:1 or lower. Compression ratio is what mainly dictates the need for premium. The higher the compression ratio, the greater the need for premium fuel.
Hemi 5.7L- 10.5:1
GM 5.3L- 9.6:1 for non-Ecotec (11.0:1 for 2014+ Ecotec)
GM 6.0L- 9.7:1
GM 8.1L- 9.1:1
Ford 7.3L- 10.5:1
Bingo^^^^
Chevy 6.2 ---premium gas
Lwiddis
Apples and oranges comparing the 6.2 with other engines. Follow the manufacturerโ€™s guidance.
ShinerBock
Hemi 5.7L- 10.5:1
GM 6.0L- 9.7:1
GM 8.1L- 9.1:1
Ford 7.3L- 10.5:1
kellem
I've towed with (2) 5.3 Chevys (1) 5.7 Hemi and now a 7.3 Ford and all have had no issues with Regular 87.
Sandia_Man
Can't speak to the Chevy 6.2 engine, but use regular with our 8.1, 6.0, 5.7, and 5.3 GM engines without issues or pinging. Only vehicle that gets premium is my wife's Caddy, runs great on regular but it is her car and she wants her baby to have the best.
Dick_B
I have the 6.0L engine and use the cheapest gas; no ping.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
ShinerBock
There have been multiple 6.2L owners here stating that theirs would ping horribly with regular unleaded.
