Removing pine pitch
ssthrd
After a few days surrounded by Douglas fir trees, we noticed a few drops of pitch on the truck and trailer. After 10 days, it turned into a real mess.
Does anyone have any suggestions on how to safely remove it from painted surfaces and especially from the awning on the TT? It's a real mess.
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
22 REPLIES 22
drsteve
Kerosene will do it.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
Capital_J
For automotive paint, I have always used acetone (nail polish remover ... but make sure it's one with acetone. I've never had any damage whatsoever to the paint. However, I would not use this on vinyl or other material without testing it first on an inconspicuous area.
98coachman
If it is fresh vinegar works very well, but don't wait. The dryer it gets the harder it is to remove. Good luck, Bill
CavemanCharlie
They make a product called Goo Gone which is good for removing glue. I don't know if it would work for tree sap but, it would be something to try. I would try it out in a inconspicuous place first to make sure it doesn't damage the paint.
Marktg
Rubbing alcohol
Boon_Docker
Turpentine
Have use it for years on painted surfaces and awning. Works like a charm and does not hurt painted surfaces, awning fabric or rubber membrane roofs.
gchackett
Gel hand sanitizer on a cotton ball. squirt it on the cotton ball and then let it sit on the sap spot for a few mins and it will wipe right off.
2002 Chevrolet Suburban 2500 8.1L
2000 Shasta Pheonix 268 Bunk House
Fisherman
RICK-ards Red wrote:
Peanut butter works
Hahahaha, and then the squirrels will lick it clean, no effort required.
RICK-ards_Red
Peanut butter works
2017 Coachman Catalina 25RKS
2015 GMC Sierra 1500 - Kodiak edition
ssthrd
profdant139 wrote:
Ordinary vegetable oil works on tar and sap. It's cheap, too!
I'll try it. Thanks!
profdant139
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
ssthrd
Thanks for the ideas. I have found that Goofoff was always a step behind me, so I'll stay away from that one.
Looks like I have my work cut out for me.
s1214
WD-40 or cooking spray, you need an oil based substance to work under it. For glass, I use Bon Ami or Bartenders Friend cleaning powder. Both clean without abrading the glass.
joelc
WD-40 let it sit a bit and wipe or scrape off. Works great on windows and painted metal surfaces of your vehicle.
